side marker rewiring
Old Mar 12, 2006 | 04:07 PM
JLEEzAP2's Avatar
Default side marker rewiring
anyone know how to rewire the sidemarkers so they stay on with the headlights and blink alternatively with the signals?
Old Mar 12, 2006 | 10:40 PM
JLEEzAP2's Avatar
anyone?
Old Mar 13, 2006 | 05:04 AM
WLAURENT's Avatar
Have not looked at them in a while - thinking they are just on solid now when the head lights are on? Correct me if I am wrong.
Assuming I am correct you could tap into the turn signal on each side. Use that 12 volt signal to trigger a relay. Wire the side marker lights to the normally closed contact - whenever the turn signal lamp blinks on the side marker would go off.
Old Mar 14, 2006 | 07:13 AM
DrEvil's Avatar
I think you will have to get a dual element bulb and socket, then wire one to parking lights and the other to turn sugnals.
Old Mar 14, 2006 | 06:50 PM
modifry's Avatar
Honorary Member
And the "side markers", as they are always (incorrectly) called, are really side turn signals. I wonder how that nomenclature got started?
^This is the easiest way to do it. Re-wire the signals so they are powered via the headlight circuit but feed them through a relay that is powered by the original side signal wires. Then when the turn signals flash the side signals will flash too (but opposite of course).
CitadelBlue
Mar 10, 2015 01:17 PM
wiley_s2k
May 11, 2012 02:13 AM
bbss2k
Jan 25, 2012 05:25 AM
bayarea408
Sep 1, 2008 07:43 AM
