a simple cost effective deterrent
Old Mar 3, 2004 | 08:27 PM
Willie Gee's Avatar
Default a simple cost effective deterrent
Hey guys I came across this in another thread,
"Bought a 12v flashing red led. drilled a small hole just behind the brake lever. Mounted the LED. Connected the negative to the ground switch of the brake lever and the posative to a constant 12v source. Now when the parking brake is engaged the LED flashes and it looks like you have an alarm. It also is a good indicator that your brake is on."
I live in an area that doesn't have all that much crime, so I'm thinking that a flashing red light might be a simple cost effective deterrent. Where is the flashing led placed when most alarms are installed? On the dash or center console?
Old Mar 3, 2004 | 10:40 PM
Mannn's Avatar
good idea
Old Mar 4, 2004 | 04:28 AM
darkknight1999's Avatar
Yeah I like that idea
Old Mar 4, 2004 | 07:06 AM
PJK3's Avatar
most alarm LED's are placed based on the car itself... generally in a very visible area... i think the center console is a great location, but due to the high cost of replacement (if goofed), i ended up putting mine on the driver's side A-pillar. i have some mild regrets about that now...
Old Mar 4, 2004 | 08:13 AM
PortugueseS2K's Avatar
Good idea especially for those with the factory alarm without a Led
Old Mar 6, 2004 | 02:38 PM
b0mbrman's Avatar
Yup. When I got my alarm, I drilled the LED right into the shifter housing (That metal-looking piece of plastic)
Old Mar 6, 2004 | 02:52 PM
Willie Gee's Avatar
Here's a picture of what I want to access to wire the LED. The photo was suplied by Cottoncb. THANKS!
The center console is from an 03 s2k or earlier. My s2k is an '04. I want ot be able to get to these wires in my '04. I don't kno where the clips are to remove the console.
Any suggestions?
Old Mar 6, 2004 | 02:53 PM
Willie Gee's Avatar
HERE's the pic.
Sorry about that, I'm a bit of a doofus.
Old Mar 7, 2004 | 07:33 PM
WPS's Avatar
WPS
im interested also.
is there a way you can install it on the steering column? which wires would you tap for the power(12v),ground, ignition(ground w/ key off)?
where can you buy a led that comes prewired for the 12v , ignition, ground?
or does anyone know if you can order the stickers that come with the alarm to put on the window?
klaxian
May 20, 2013 07:30 AM
tntrac
Sep 6, 2010 10:25 AM
GyozA
Jul 29, 2007 10:33 AM
Mattyboyz
Apr 8, 2007 04:21 AM
joej
Aug 5, 2005 06:05 AM
