Softer horn?
Old Mar 31, 2006 | 12:13 PM
S2Koupe's Avatar
Default Softer horn?
im wondering if theres a softer horn alternative than the stock "honk" after you lock the doors using the stock remote. more like a bmw whistle, instead of the obnoxious honk. (if anything, id replace the horn with sometihng louder, but not if its going to honk every time i want to confirm the doors are locked)
anyone in the car electronics business know? is there a similar option for aftermarket alarm and remote systems?
thikning more about it, i think there would be an issue with the actual alarm also running off the same, quieter buzzer, which would defeat its purpose... hmmm... does anyone know a way around that? or is it a separate relay when the alarm goes off?
Old Mar 31, 2006 | 12:24 PM
viper7169's Avatar
I'm working on a project to make the car "beep" instead of honk when you lock the doors. The relay is tied solely to the keyless entry circuit, so I don't think it will affect the alarm. Stay tuned to the electronics forum.. I should have it installed and posted sometime this weekend.
Old Mar 31, 2006 | 12:27 PM
Saki GT's Avatar
You can program the car not to beep when you lock the doors through the fob - search the forums and see what you get, but its pretty straightforward.
Old Mar 31, 2006 | 01:47 PM
tcho82's Avatar
Either one, dont press your key fob twice. or two get an aftermarket alarm that will just bypass your honk.
If the sound is all youre looking for a cheap alarm that can unlock your doors and trunk will do the trick.
Old Mar 31, 2006 | 02:58 PM
SheDrivesIt's Avatar
You should hear the AP2 horn when you double click the remote. It is really obnoxious.
Old Mar 31, 2006 | 03:02 PM
xviper's Avatar
If you need confirmation, why don't you just look back at the car when you hit the button the first time? You will see the park lights blink. I only ever hit the button a second time if the sun is too bright for me to see the lights. On the other hand, if I'm close enough, I can hear the door locks click. At least for me, this is a non-issue.
Old Mar 31, 2006 | 03:04 PM
CitadelBlue's Avatar
so what is the purpose of the horn sound when you double click the remote?
Old Mar 31, 2006 | 03:15 PM
xviper's Avatar
The first click, we get a visual confirmation that it locked. The second click, we get an audible confirmation that it locked in case you didn't catch the first one. You know, in case there's a couple of blind car thieves waiting to jack your car.
Old Mar 31, 2006 | 03:43 PM
wanabe's Avatar
i have dual hella air horns-
when i lock the car its a mild sound...
when i need to really use the horn, its a hella loud horn!
Old Mar 31, 2006 | 05:08 PM
S2Koupe's Avatar
is that because its such a short blip?
some of you are right tho, it really isnt completely necessary to press the lock twice. but sometimes i forget to lock it (not used to a car with a remote) and if i do remember, im a bit of a ways away i wouldnt be able to hear the doors lock or see the parking lights, so the audible confirmation is helpful.
