soldering wires?
Old May 25, 2003 | 10:31 PM
SaNgO5's Avatar
Default soldering wires?
is soldering the wire more efficient vs. crimping the wires together and putting electrical tape over them. i know that method is not very well taken in vs. the soldering methoc but i was wondering if there were actually efficiency differences between the 2 methods. as in sound quality, power transfer, etc? thanks
sang
Old May 26, 2003 | 04:34 AM
Zich's Avatar
Unless you're an audiophile, you probably won't notice the difference, unless your crimped connection falls out but yes, soldering is a better connection.
Old May 26, 2003 | 04:36 AM
MacGyver's Avatar
Soldering offers a more solid connection, but sometimes it's difficult or near impossible to solder a connection if it's in a tight space. You will never be able to hear a sonic difference between the two...even the self-proclaimed audiophiles who swear they can with their "golden ears" are proclaimed by everyone else to be full of BS.
Old May 26, 2003 | 06:02 AM
PJK3's Avatar
[QUOTE]Originally posted by MacGyver
[B]Soldering offers a more solid connection, but sometimes it's difficult or near impossible to solder a connection if it's in a tight space.
Old May 26, 2003 | 07:46 AM
modifry's Avatar
Honorary Member
Soldered connections are less likely to come apart with physical stress and less likey to corrode over time, but for all parctical purposes (life of your car etc) a crimp connector is just as good. Think about this - what does the phone company use to splice wires? Solder?? No way - everything they do is with crimp connectors. If you use the right connector and a good crimp tool you won't have any problems.
Personally, I usually do solder connections simply because it's smaller. When you get a dozen crimp connectors in a bundle it makes a pretty big wad, and you can solder and heatshrink without getting much fatter that the original wire.
Old May 26, 2003 | 08:09 AM
SaNgO5's Avatar
okay thanks for all the info! =D
sang
PWRMKR's Avatar
Only if you know how to solder . Most amateurs (me) have a hard time getting even temp through ALL the wires. This is needed for proper flow and placement of the solder.
but for all practical purposes (life of your car etc) a crimp connector is just as good.
Especially for one who has the above problems :
Old May 26, 2003 | 01:01 PM
Zich's Avatar
I find that for terminals, a torch is the impatient man's perfect tool
Old May 26, 2003 | 08:17 PM
Andy Kirk's Avatar
I did solder the connections for my new Hu into the car harness, no addaptor as I was concerend about room. Heat shurnk tubing onto the wires but I have had considerable experience soldering wiring.
Andy
Old May 27, 2003 | 06:00 AM
smyroad's Avatar
[QUOTE]Originally posted by PWRMKR
[B] Only if you know how to solder .
