Sound system stopped working.
Old Sep 22, 2010 | 08:47 PM
PUNCHIN-IT's Avatar
What are the specs for your system?
Its usually better to have your sub running off its own separate amp with a capacitor. Your amp may not have enough juice? How many watts is your sub and speakers?
Does the music shut off when the volume is high/low?
I have a similar set up as yours with 2 components and 10'' sub. I run 2 separate amps. One for the components and one for the sub. The sub has a capacitor.
Old Sep 22, 2010 | 08:50 PM
Moddiction's Avatar
Former Sponsor
I really don't know the wattage or anything for my system.
Never had any issues before now. I don't think there is an issue with enough juice. Had it for a couple years no with zero issues with the system.
I am perfectly fine with the sound level and all now. I think the amp was maybe 800W. It is a soundstream van gogh amp I think it is called. Something like that.
Old Sep 22, 2010 | 08:51 PM
Moddiction's Avatar
Former Sponsor
It looks just like this but not sure of the model number or anything.
http://www.sonicelectronix.com/item_997_So...s+VGA320.4.html
Old Sep 22, 2010 | 08:52 PM
PUNCHIN-IT's Avatar
Oh you had the system for a couple of years...
Than I would say your amp is toast.
Old Sep 22, 2010 | 08:55 PM
PUNCHIN-IT's Avatar
If you weren't running the proper wattage amp for your set up that could have been the problem. By the way you described everything, your amp looks to be done.
Old Sep 22, 2010 | 08:58 PM
Moddiction's Avatar
Former Sponsor
So it's actually the exact one I posted. I just double checked.
So i guess that is a pretty low watt amp right?
Would I want something with a lot more wattage?
Sound level was fine for me but see most other amps have tons more power. If I got a higher watt amp would I need anything else to run it? If so I don't want that.
Old Sep 23, 2010 | 06:16 AM
oth's Avatar
oth
From your description, there's no way to tell if the problem is a bad
amp, a bad headunit, a short in the speaker wiring, loose wire, or even
simply a bad fuse. you'll need to find someone with a multimeter who
can methodically trace through and figure out where the problem is.
That amp appears to have LEDs on the top indicating if it's in protect mode,
and possibly even why. UCP is right, look at the amp and see if it's in
protect mode, and go from there.
Old Sep 23, 2010 | 09:13 AM
PUNCHIN-IT's Avatar
Not to be an ass. But, actually you can tell. It just may not be 100% accurate because of the lack of info. My brother had a similar problem to mod's. In his case his amp died because the amp rating was lower than the required load for his system. He didn't push his amp to the limit always, but over time it took a toll on the useful life of the amp. He got the right amp, and has never had a problem since.
I agree though. I didn't see what UCP said, but you should check your amp settings.
Btw, that amp seems extremely weak to power your setup. Unless you have very weak components and sub.
Old Sep 23, 2010 | 11:00 AM
UCP's Avatar
UCP
There's no reason that amp couldn't work unless set it up wrong.
80 watts RMS is more than enough for most consumer grade speakers.
Old Sep 23, 2010 | 11:20 AM
MattZ28's Avatar
I've got a nice JL 500/5 amp sitting in my garage, but it has a short somewhere. JL charges a flat $180 fee to replace the guts, with a warranty included. If you're interested I'll let it go cheap.
