Speaker / amp power compatibility question
I have Polk component door speakers but have forgotten the exact power ratings. I think they are 'es650' and I remember 100W max recommended RMS. The current Polk speakers claim 100W RMS/ 300W peak.
I am considering an amp that claims 150W RMS and 200W peak. Is the 150W RMS going to blow up my speakers?
I was considering the Blaupunkt pa2150. I understand they quit making this line and I can't find the 100W version (pa2100) any more. If there are other small reasonably priced amps for under the seat, I would be interested in those too.
The amp is fine. You dont want a 100Watt amp when you Need 100 watts. take the 150 amp and back it down. It will run cooler, and last longer. YOu dont want an amp to be maxed the whole time.
All this talk of 300 watts to 100 watts speakers is nonsense. With a good amp that has headroom it is not required. There is no asterisk here. A good amp should perform beautifully in the numbers listed by the manufacturer. Note that that is why I asked which amp you're using. Many lower priced amps do not live up to the numbers in the brochure.
That Blaupunkt is not the right amplifier. A class T amplifier is not ideal for front speakers. PM PJK3 or google this topic for more info on that. You really should stick to class A. Try this Soundstream Edge 360/2 for $95. It's 90 watts RMS x 2 channels at 4 ohms. Post here if you want more amp recommendations.
http://www.discountjungle.net/soxt362chxsa.html
To clarify about class T. You could do it and the concept makes sense but I've yet to hear a good one. The promise is to combine clean class A power with efficient class D power, however I don't think anyone has done it well yet. I'd be especially concerned with this amp because it is no longer produced. If it really met every claim originally made then why wouldn't the product line be expanding instead of being cancelled?
Also note that you need a $30 tri-way crossover for the amp. I'd skip this one.
http://www.crutchfield.com/S-5oC2495k5ym/c...asp?i=023PA2150
The Blaupunkt problem was reliability, which is a common problem with digital amps. I have one on my sub (a good application for digital) and it broke once already. I was surprised Blaupunkt fixed it under warrenty since they stopped making them.
But digital amps are making some headway. TI has a little 15W chip amp that runs at 250kHz and needs next to no output filtering. Now if they can do that for 150W we'll be in business. High-freq and high power is not easy.
Do you know what "a good amp with headroom" is? It's an amp that is under-rated. Or an amp with low-current capability that can make more power short-term than it can sustain in an RMS test. Voila, headroom.
They could have easily marketed the 200W "peak" amp as 100W RMS with "3dB of headroom".
