Speaker/Tweeter Install Help
Old Jun 7, 2007 | 10:09 AM
DangerZone9K's Avatar
Default Speaker/Tweeter Install Help
Sup Fellas
I
Old Jun 7, 2007 | 10:23 AM
aite i got the bracket off but i dont see a hole on the back of the tweeter for the screw... should I just use double sided tape or screw?
Old Jun 7, 2007 | 10:30 AM
S2kPerez's Avatar
super glue is holding mine quite well
Old Jun 7, 2007 | 10:34 AM
imagine's Avatar
I used double sided tape. It will hold it pretty well.
Old Jun 7, 2007 | 10:45 AM
ok the tweeter will be put on by double sided tape...
my next problem is that the bracket for the speaker does not line up with the holes.
Old Jun 7, 2007 | 10:50 AM
imagine's Avatar
I believe you mount that bracket on to the stock bracket?
Or get a custom one made.
Old Jun 7, 2007 | 11:03 AM
I tired putting the polk bracket on the stock bracket and it does not fit... I'm going to drill the polk bracket to make the screws fit. Also the bracket didnt come with any screws..
Old Jun 7, 2007 | 11:09 AM
JackS's Avatar
I just put in the DB6500 and the woofer should fit the stock basket using three screws only. However the stock screws won't be long enough to use the foam or felt gasket. I just omitted this on mine but you may prefer to get longer screws.
If you don't have the adapter (two wire plug-in) for the woofers, you'll have to cut the stock adapter off and splice into the two existing stock wires and add about a foot of extra wire to reach the opening next to the slot where the crossover box will be placed.
Old Jun 7, 2007 | 12:40 PM
okay... I got the polk audio bracket to fit.. now i need help wiring everything together like tweeter/speaker/crossover. My speaker does not have a adapter
Old Jun 7, 2007 | 01:05 PM
the tweeter wire connects to the crossover...
the woofer wire connects to the crossover and everything should work right?
