Speaker wires
Old Feb 22, 2012 | 05:42 PM
5STARSTUNNA's Avatar
Default Speaker wires
Wanted to ask what gauge wires are you guys running on your components? From tweeter to crossover, door speaker to crossover, and crossover to amp? Right now I have 12 gauge rockford fosgate wires but the sleeves are thick. I dont know how I can get these threw the door.
Old Feb 24, 2012 | 09:13 AM
JohnsS2000's Avatar
use a metal hanger and cut the flat bottom peice off and go from the door into the car. Take about 6 inch's of the wire and electric tape it to the hanger section you cut off. I just did this with speaker wire. The wire was apx 1/4 inch X 1/8 inch in dimention. There is a black rubber peice between the door and car that you will ba able to make the wire go through just make sure when you push the metal hanger peice through the door side you do it close enough to the other wires, and be sure there are not sharp spots on the cut peice of that metal hanger peice
Old Feb 24, 2012 | 09:25 AM
Ragnarok043's Avatar
silicone spray will also help get it past the rubber boot
Old Feb 27, 2012 | 04:55 PM
skibbz's Avatar
12 gauge wiring to your components sounds waaaaaay overkill, unless you're running like 750 watts to each set of components. 16 gauge should be sufficient for typical car audio installations, even fairly well powered setups.
http://www.bcae1.com/wire.htm
jeffbrig
Oct 15, 2017 06:35 AM
braeden
Apr 10, 2014 06:21 AM
sweetsleeper
Aug 25, 2005 05:25 PM
2000celicaspeed
Sep 26, 2004 08:48 AM
matrix
Mar 31, 2003 06:43 PM
