Speakers are whining
Old Aug 9, 2013 | 06:13 PM
komatsuman's Avatar
Default Speakers are whining
Intermitent whine from speakers, coincides with volume on radio, not with engine rpm's. Should I pull the HU and check the ground? Can it be related to a bad battery? Help, Please!
Old Aug 10, 2013 | 10:14 AM
BLAQ&GREYs2k's Avatar
What kind of audio setup do you have? HU, aftermarket speakers, subwoofer, amplifier, etc. Have you replaced or repaired anything regarding grounds or the battery?
Old Aug 10, 2013 | 11:01 AM
komatsuman's Avatar
Completely original, untouched 04. Even original battery, which still tests good. Only option is headrest speakers. Where is the ground for the radio, since that may be my first suspect.
Old Aug 10, 2013 | 02:50 PM
The original headunit ground would be a good place to start. The headunit gives the signal to the speakers, the speakers are just drivers. There is definitely an issue with the headunit. If the ground is ok, perhaps you have a friend with a spare aftermarket HU to plug up briefly to see if the sound reoccurs.
Old Aug 11, 2013 | 07:51 AM
oth's Avatar
oth
does it happen with both radio and CD, or just one?
Old Aug 11, 2013 | 09:33 AM
komatsuman's Avatar
CD works great, no squeals. Here's what I did this morning:
Removed the HU from the dash, did not disconnect any of the connections, but checked to see if they were tight. Wiggled them around, no change. Still have squeal in lower number radio stations. One station comes in clear, the others seem to be searching for a signal.
I just put a CD in the slot and the squeal goes away. When I switch over to radio, the squeal is gone until I hit a station change button and the squeal comes back.
What now?
Old Aug 11, 2013 | 09:35 AM
komatsuman's Avatar
With all the posts about changing out the HU's to different makes, there should be some good HU's out there for sale. Do you know where the HU is grounded at?
Old Aug 11, 2013 | 09:52 AM
oth's Avatar
oth
Doesn't sound like a grounding issue; would happen no matter the source. In addition, the headunit
is grounded both through the harness as well as the case, though they may or may not be electrically
isolated from each other.
If it was a stray source of RF, it would only be on the radio, but would not be affected by hitting
buttons. Sounds like it's a failing headunit.
The marketplace forum frequently has headunits removed for aftermarket upgrades - make sure you get
the code with the headunit.
Old Aug 15, 2013 | 12:48 PM
komatsuman's Avatar
Well gentlemen and ladies? It was the HU. Bought one from S2KIOE, installed and everything is working great!
JMChristopher
Mar 7, 2014 06:29 AM
Ghregy
46
Jan 4, 2013 02:19 PM
acn684
Oct 12, 2011 03:03 PM
ft2057
Dec 1, 2007 12:48 PM
Max21
Oct 28, 2004 08:10 AM
