Spotify
Old May 20, 2016 | 01:37 AM
jonner's Avatar
Default Spotify
If we have any spotify users on board are you able to play your playlists in the car?
Just changed to a new iPhone but can't seem to get it to work?
Old May 20, 2016 | 06:07 AM
electricmarauder's Avatar
Do you have a paid subscription?
From Spotify (for mobile):
Why can’t I play a specific song?
Streaming on demand is a Premium-only feature. To play any song, anytime, just upgrade to Premium.
Old May 20, 2016 | 07:55 AM
AE_Racer's Avatar
Ive run into a problem with my iphone before where it wouldnt play any music or apps through the headunit unless there was atleast one song stored on it. I found a free one to download and then it worked fine.
Old May 22, 2016 | 03:23 PM
cosmomiller's Avatar
Top Answer: 1
Get an Android. Really easy to work. Just dump music on it like a drive instead of screwing around with the iTunes store garbage. My Note 4 streams beautifully and with T Mobile it does not come off the data plan. Removable battery. Removable memory chip.
Off the grid (deep in canyons) just use what is stored or listen to the engine wail.
Old May 23, 2016 | 01:16 AM
jonner's Avatar
I do. Even if you have the offline mode on i still can't get it to work. It will work fine offline but can't get it through the car though.
Old May 28, 2016 | 05:12 PM
Richdel's Avatar
You didn't mention if this is stock HU or a head unit with aux/BT input.
I have a Kenwood x998 and use Spotify all time. I use it in offline mode, and use Bluettoth to transmit to the Kenwood.
Works like a charm. When I turn the vehicle off, then return, after the car has started (about 15 seconds afterwards)Spotify
begins playing again from the exact spot it stopped at. I have noticed that the volume using BT is significantly louder then when
I use a 3.5"-3.5" cable in the aux jack. That seems very weird to me.
Old May 30, 2016 | 01:18 AM
jonner's Avatar
Originally Posted by Richdel
Originally Posted by jonner' timestamp='1463994998' post='23973891
[quote name='electricmarauder' timestamp='1463753270' post='23972076']
[/quote]
It's an aftermarket Alpine head unit. I have tried it as an aux input and blue tooth but still no joy
Gaspode
Nov 16, 2009 02:54 AM
r_duff
Aug 1, 2008 11:42 PM
