Start button to ignition switch change
Old Mar 3, 2011 | 11:33 AM
Ludicrous Speed's Avatar
Default Start button to ignition switch change
I'm getting ready to install a turbo kit and will be modding the radio control pod to add my boost controller there.
The boost controller is 66mm, which leaves little room for the start button. I'm thinking about switch the start button over to this:
Longacre Ignition Switch
This would give me the room I need.
Anyone have any experience or thoughts about changing over?
Thanks!
Old Mar 3, 2011 | 11:40 AM
aphex4000's Avatar
Thanks!
I may not be understanding what you're proposing correctly, but if the plan is to replace the push button ignition start switch with this toggle switch then it should not work. The OEM start button is a momentary switch while the one shown appears to be a toggle switch. Wired into the original circuit path, the new switch would leave the starter spinning for as long as it is toggled on.
Old Mar 3, 2011 | 11:47 AM
Originally Posted by aphex4000
I may not be understanding what you're proposing correctly, but if the plan is to replace the push button ignition start switch with this toggle switch that I should not work. The OEM start button is a momentary switch while the one shown appears to be a toggle switch. Wired into the original circuit path, the new switch would leave the starter spinning for as long as it is toggled on.
Correct, but you would only engage the switch long enough to start the engine, then return it to the off position.
Old Mar 3, 2011 | 01:10 PM
elmoEF9's Avatar
You can buy a momentary toggle switch.
Old Mar 3, 2011 | 01:46 PM
suzuka-blue-s2k's Avatar
This..
Old Mar 3, 2011 | 01:47 PM
aphex4000's Avatar
I agree with elmo. You can get the cover and switch separately for the same appearance. Look for "44218 Red" here and just pair it with one of their momentary toggle switches.
Old Jul 29, 2013 | 12:30 PM
spdoran's Avatar
I'm going to go ahead and bring this back to the top.
Has anyone successfully done this? What parts? Pics?
Old Jul 30, 2013 | 12:21 PM
spdoran's Avatar
I'm really just concerned about if the car will allow this to happen. I have an 06 AP2 and I know I can do all of the work, but will the toggle switch do the same and work as if it is the start button?
Old Nov 10, 2017 | 09:49 AM
gomboy86's Avatar
this was an interesting thread. anyone ever get it done?
Old Nov 10, 2017 | 10:38 AM
flanders's Avatar
There is nothing special with the oem start button just replace it with whatever you like, a momentary switch is recommended though.
