Static noise in my tweeters when car is turned on.
Hi, I put my audio system together and now i just have a problem with static tweeters. It only comes on when i turn the ignition. Im not sure if i need to tap into my stereo HU ground but i bought the PnP modifry plug and saw that the ground was directly plugged into the harness.
Do I need to tap into the ground and ground it?
my amp is grounded in the trunk. I don't know if this is a good grounding location because of the paint...
anyone know another good grounding location in the trunk?
So far this is what I have purchase. Please let me know what I am missing to make this all work.
Head unit
Alpine iDA-x303
Component 2-way speakers
Amplifier
Amplifier wire installation kit
DCI modifry
Alpine PnP harness
Alpine KCE-433iv Full speed cable Charge and Control iPod iP
Speaker spacer 6.5" 1/2 inch
Do I need to get a 4 channel RCA cable?
and do I need a battery terminal?
Head unit
Alpine iDA-x303
Amplifier
DCI modifry
Alpine PnP harness
I think the boss amp wire kit comes with one I can't tell from the pictures, but here's the description of what's included in the kit.
Red power cable: 20 feet, 8 gauge
Black ground cable: 3 feet, 8 gauge
Turn-on wire: 16 feet, 18 gauge
Speaker wire: 30 feet
High performance RCA interconnect: 20 feet
Split loom tubing: 6 feet
Wire ties: Twenty 4-inch
Grommets: 3 rubber
Ring terminals: #10, 0.25-inch, 0.31-inch
Other: Competition high-quality fuse holder
Just curious but do you need the Ipod cord or does the one in the box work? I am doing my install this weekend and did not buy that
Actually scratch that... I got the Alpine IDA-X305S receiver and according to crutchfield the USB port is the better way to go. Some of the older Alpine receivers don't have the USB which require that cable. Are you sure that is the best way to go for your receiver? I know nothing so don't go by me...
ALPINE KCE-433iV is for direct connection that's a lot faster than connecting with the USB they give you. Also, give you a full control on your ipod.
Originally Posted by niptek' timestamp='1304451171' post='20533941
[quote name='darkalley' timestamp='1304433016' post='20532598']
Damn, I'll just have to return mine.
Does anyone know if I can install my fuse holder in the trunk area or does it have to be install under the hood?
[/quote]
With my setup what sub woofer should i get?
Im planning to get a 10" sub to put in the tool well area.
anyone try this 10" sub box for the tool well?
It's all made out of MDF. They didn't use any fiberglass so I don't know if that will make any difference.
It's 75$ shipped on Ebay versus Darksidesub.com 200$
Will this work for my setup?
