Stock Radio stays on after ignition off? HELP !
Old Apr 16, 2008 | 06:08 AM
04s2kWPB's Avatar
Default Stock Radio stays on after ignition off? HELP !
finally got some nice weather up here in Cleveland....nice and early this year its only 4/16
Took the S2K out for the first spin of the year... when I shut it off the Radio and hardwired V1 both stayed on after the ignition was off.. What is going on here???
I'm not very electronically inclined so any help would be greatly appreciated....Thank You !
Old Apr 16, 2008 | 06:17 AM
SheDrivesIt's Avatar
Does it go off if you open the door? If so, normal.
Old Apr 16, 2008 | 06:29 AM
04s2kWPB's Avatar
no it doesn't...very strange
Old Apr 16, 2008 | 06:52 AM
oth's Avatar
oth
when you say "ignition off" do you mean even with key totally removed?
here are two possibilities - a failing ignition switch, or more likely a stuck
relay. If the switch, I imagine that everything that normally goes off when
you turn off the car would stay on. If a relay, only the things on that
circuit. I know the radio and accessory socket are on the same relay, but
am not sure where your V1 is hardwired from (and even if you told me I'm
not sure I'd know if was on the same circuit unless you knew it was on the
same fuse).
In any event, I'd try turning the car on/off a few times and if that doesn't
work try a nice drive.
Old Apr 16, 2008 | 07:07 AM
04s2kWPB's Avatar
same fuse).
only the radio and V1 stay on..must be on the same relay right?
Old Apr 16, 2008 | 07:10 AM
oth's Avatar
oth
seems likely to me.
Old Apr 16, 2008 | 08:28 AM
MikeyCB's Avatar
Here's something I noticed:
I had a 300w inverter plugged in to my power outlet and when I would shut off the car the radio would remain on. I suspect there are some capacitors in the inverter that were actually powering that circuit once the feed from the alternator and car battery was removed. Hence, the radio stayed on (for about 10 or 15 seconds.
spdoran
Jul 25, 2012 03:26 AM
ems2000
Jan 14, 2012 10:06 PM
FONK
Jan 2, 2010 05:12 PM
Timphan84
Oct 10, 2007 08:45 AM
AustinS2k2003
Jul 18, 2003 07:53 PM
