Stop horn from sounding when alarm is set?
Originally Posted by freq,Oct 12 2004, 10:37 AM
Additionally my alarm will set itself if left alone for about a minute or so, does everyone elses do that?
Originally Posted by NECurve,Oct 11 2004, 10:07 PM
When I come home late I can't park in the garage because the noise will sometimes wake the baby. So every once in a while I will park in the driveway......but even setting the alarm will sometimes wake the baby if the windows are open.
Does anyone know how to make it so that when you turn on or turn off the factory alarm system that it ONLY flashes the lights and does not honk the horn to let you know that the system has engaged.
Thanks for the help!
Second, read your manual. It will tell you how to change your alarm from "chirp" to "silent." It could either be a one time button/key/remote sequence or a DIP switch on the alarm control unit.
If you want me to read your manual you will have to tell me what alarm you have, or if its OEM, what year of OEM.
If it's OEM you are right, it's not hitting the button once vs. twice. You have to change the chirp option.
- I didn't think it would be in there...
Originally Posted by dut,Oct 12 2004, 01:39 PM
- will have to read up on that...
The installation instructions are available as a PDF, but I can't find the Owner's Manual anywhere. Honda's site is nearly worthless.
Anyway, the installation instructions refer to the Owner's Manual for those preferences...
Okay, in THIS POST Revenuer outlined the steps to go from "silent" to "chirp".
The relevant part is as follows:
"It is possible to configure it so that the horn beeps once when you arm the alarm. On mine you just press and hold both the lock and option buttons for two seconds. This is a toggle so if your horn doesn't beep when you lock the doors just do this and it will, or if it beeps and you don't want it to do it and it will stop. This is set by each remote individually. That is I have it set so that it beeps when I arm/disarm the alarm and my wife's remote doesn't."
I just went outside and confirmed that it works for my car. Hold "Lock" and "Option" for a couple of seconds to get the annoying beep, and do it again to make it go away.
I have a Model Year 2000 with the OEM Security System.
Originally Posted by LATEOTT,Oct 12 2004, 02:46 PM
To clarify, it's in the Security System Owner's Manual (the little pamphlet that comes with the Security System), not in the S2000 Owner's manual.
- I only have LOCK/UNLOCK/TRUNK/PANIC.. thats it
Originally Posted by dut,Oct 12 2004, 02:23 PM
- I don't have an "option" button..
Well, maybe the Keyless Entry does the same thing. In your case you would at the same time press LOCK and TRUNK and hold them for about two seconds.
Have you tried that?
And, if you do only have the Keyless Entry (standard with the car), then it might indeed be in the S2000 Owner's manual, again, since it's a standard feature.
