Stuck CD
Old Sep 26, 2001 | 11:43 AM
sy2kwa's Avatar
Default Stuck CD
I have a CD stuck in my in dash stock head unit. Any one know an easy way to retive it other than removing the head unit.
Old Sep 26, 2001 | 12:55 PM
jerrypeterson's Avatar
Stuck? How? Look for a small pin hole anywhere on the front of the deck. You can use the end of a paperclip to manually release the CD if it has one of those. Does the deck have power?
Old Sep 26, 2001 | 01:00 PM
Pinky's Avatar
Were you playing a CDR/CDRW thats a NO NO in our stock head unit.
Old Sep 26, 2001 | 01:01 PM
aznpooky's Avatar
i play cdr's in the stock headunit without having any problems. you have problems with yours?
Old Sep 26, 2001 | 02:59 PM
sy2kwa's Avatar
I can find no small pin hole in the face plate. I already looked b4. I have power to the unit. I was not playing a CD-R. It happens to be a CD from the library that has one of their bar code on it, thus making it have a thick spot and hanging up the CD.
Old Sep 26, 2001 | 05:40 PM
MacGyver's Avatar
CDRs aren't a problem, and CDRWs will give you a read error most of the time (but should never play).
The stock unit has no pinhole, and taking the damn thing's covers off to get to the internals doesn't work either (can you tell I've had to do this before? ). Your best bet in this case is to use some tweezers with electrical tape on the tips and pull as you press eject. There are some surprisingly heavy-duty metal door thingies (that's the technical term) that are in the basic path of the CD eject, and they're a bitch to get around. You take a chance of losing the barcode in there (you can take the covers off to get to that, though), but at least you get the CD out.
Out of curiosity, why are you putting something from the library in your car CD player?
Old Sep 27, 2001 | 01:57 PM
sy2kwa's Avatar
Thanks for everyones input! I was able to get the CD to eject by inserting a nail file and using the eject button.
After paying the ridiculous price plus markup, I can no longer afford CD's!
The CD in question was"The Raw and the Cooked" by Fresh Young Cannibals.
Old Sep 27, 2001 | 02:04 PM
Mindcore's Avatar
Let me guess it jammed on "Good Thing"?
You didn't hear it from me, but check out Kazaa
Old Sep 27, 2001 | 03:17 PM
MacGyver's Avatar
They have music CD's at the library? Holy cow, I feel an upgrade to my MP3 collection coming
Old Sep 27, 2001 | 04:36 PM
Pinky's Avatar
The reason CD-R's are a NO NO is that they are not supposed to be played in our head unit. Its not CD-R compatable! Only just recently have radio's started comming CD-R compatable. Pioneer was one of the first ones to have that. And even still there are radios that don't support it.
They will play fine for a while but after a while the extra weight of the CD-R will take its tole on the motor and it will fail far far earlier than it should.
