Stupid amp question
Old Sep 26, 2005 | 06:12 PM
naseeb's Avatar
Default Stupid amp question
I purchased some polk db6500's( better than average speakers) and running it off an Alpine HU.
I'm running the speakers directly from the HU and at around mid volume the sound is distorted and saturated. I tried messing around with the EQ, and I still get crappy sound. My OEM speakers sounded better.
1.Do you think driving the componet speakers with the HU is the culprit?
2. Will an amp greatly improve the punch?
3. Are these speakers just crap( I purchased them because they were easy drop ins)..... ( no flamin please)
I feel the install was clean. All the wires were soldered.
4. I'm not sure, but is it possible that compression may be caused by having the +/- polarites reversed on the speaker connections .....just a possiblity, but I think I wired it correctly.
Old Sep 27, 2005 | 04:22 AM
sctyboy's Avatar
Get an amp.
(I bought the same speakers, and drove them with ah eadunit and thought... this sucks.)
I got an amp and am quite happy now
Old Sep 27, 2005 | 04:34 AM
bmcwhirt's Avatar
I don't think they should sound WORSE than the factory speakers. I'm guessing the polarity is reversed on one speaker. They are out of phase. One (unscientific) way to test it is to turn up the volume to a level that sounds crappy and move the balance all the way to one side. If it sounds better thru one speaker, they are out of phase. If the speakers are out of phase, an amp will not help. It will just make the crappy sound LOUDER.
Old Sep 27, 2005 | 06:12 AM
naseeb's Avatar
Thanks guys....
I will try the unscientific approach to see if I have a phasing problem..
BTW: last night I read the Alpine manual and figured out how to properly use the EQ. I now get a wider bass response, and the speakers do sound a lot better. I still feel in order to fill the low range void, I will need a sub.
JD NC
Jan 31, 2013 09:26 AM
ProV1
Nov 6, 2005 08:27 PM
p0pe
Jul 18, 2005 12:08 PM
TwistedS2k
Aug 27, 2004 09:56 AM
ErikKlenke
Jul 25, 2001 12:39 PM
