Stupid sub question?
Old Feb 1, 2006 | 04:06 PM
Sakislayer's Avatar
Angry Stupid sub question?
Stupid sub question that I couldn't find an answer for in the forum.....
I purchased a Wlaurent V2 sub enclosure and my sub (Infinity perfect 10) came today and the very bottom edge of the magnet just touches the bottom of the box. I think I could probably take a dremmel and widdle down the boarch just a touch to get the sub in there. I mean we're talking about 1/16 of an inch.
So my stupid question is this --- what happens, is it bad, will I screw something up? if the sub's magnet, or metal underneath the magnet touches the sub enclosure? Like I said, we're just talking about the very edge...
I asked the guys at Crutchfield and they said it's okay for the magnet or sub's metal enclosure to touch a sub boxes enclosure so long at the hole in the bottom of the sub isnt' covered. Evidently subs need those holes to "breath"...
So -- guys -- what do you think?
Wlaurent -- you were right -- you needed to test fit it!
Old Feb 1, 2006 | 04:12 PM
boyguan's Avatar
well i wouldnt grind the box if anything. its probally not very thick and you can easily wear a hole.
is there a cover or anything on the magnet u can grind off?
Old Feb 1, 2006 | 06:25 PM
Sakislayer's Avatar
nope..... it's the very edge of the magnet and the edge of the metal behind the magnet. I mean, I had push it hard into the box and twist the sub back and forth to make a mark inside the enclosure. When I did that it left a small black mark on the edge of the sub itself so I can see where it's hitting on the sub as well.
I have no doubt I can get the sub in there and it would just take a slight trim in the enclosure. My question is will it be okay if the magnet and/or speaker rear metal support (whatever it's calleda) touch the enclosure?
I'm thinking it would be okay..... but I'm curious is anyone else has a sub that touches the enclosure.
Old Feb 1, 2006 | 08:08 PM
WLAURENT's Avatar
It will not matter if the sub touches the enclosure. The fiberglass is only a couple 2 or 3 mm thick and is a little bit flexible on the bottom/base (assuming the rub is on the base??).
I would not recommend grinding on the fiberglass.
Can you send me a picture of where the rub is inside the enclosure?
Old Feb 1, 2006 | 08:18 PM
darkknight1999's Avatar
I would just make a spacer and leave the box alone.
Old Feb 2, 2006 | 06:43 PM
Nugget's Avatar
You want at least a 1/2 inch at a MININUM between the magnet and the back of the sub box. This information comes directly from Infinity, whom I spoke with yesterday. I was looking at the same sub, but am not getting it for the exact reason you found out. It does fit and he said the sub will last less than a year.
Call Infinity technical support if you want further info.
Good luck
Old Feb 2, 2006 | 08:01 PM
That's why I think he should just make a spacer.
Old Feb 3, 2006 | 03:46 AM
Sakislayer's Avatar
crap..... I guess I'll have to make a spacer. It's just the very edge of the magnet that touches. I wonder if Infinity means if the hole in the magnet is covered -- like Cruthfield said?
Wlaurent -- I'll try and snap you a picture later today and send it to you. It is the bottom of the enclosure where teh magnet is touching. I can get the sub into the enclosure and secure it (as you said the bottom is somewhat flexible). I was just worried about how the sub would sound and also about possible damage.
as for the spacer -- any recommendations? MDF? I only need about 1/16 of an inch... maybe an 1/8th.
Old Feb 3, 2006 | 04:24 AM
mas's Avatar
mas
Might as well make it 1/4 inch thick. MDF should be fine, check with local car audio shops, you might find a pre-made one.
I ran into this issue when I was in a similar situation a while ago and the answer I found was yes you need to leave some room for the sub to "breath" or rather vent so it stays cool, etc.
Old Feb 3, 2006 | 06:57 AM
WLAURENT's Avatar
Good luck
There is plenty of space for the VC vent on the back - issue is diameter of the magnet.
I had requested that the sub be sent to me for fitment, unfortunately the buyer did not have a way to get it to me in time to meet his project timeline.
