tein edfc
Old Mar 31, 2008 | 09:11 PM
cbrguy7's Avatar
Default tein edfc
I'm havin trouble installing my edfc, I have the full time power, and ground figured out but I cant figure out where to hook the otehrs up to
(I have it located next to my left knee so I need to use wires under the dash, not wires to the stereo or the cig lighter..)
Old Apr 4, 2008 | 09:18 AM
cbrguy7's Avatar
bump anyone know?
Old Apr 6, 2008 | 10:25 AM
U9aXy6Dn's Avatar
not seeing the wiring diagram, it makes it kind of hard.
i'd imagine, in addition to live ang round, it might have a backlight control to pickup when it needs to light up (auto dim with the oe loom etc)
that sound closer to the problem?
pictures ALWAYS help.
Old Apr 6, 2008 | 12:52 PM
cbrguy7's Avatar
I guess I could start over and say I dont know where all the wires go for the edfc, so when wiring them under the dash by your lower left knee what wires would you tap into?
Old Apr 6, 2008 | 01:12 PM
WLAURENT's Avatar
How many wires are there and what are they all called. Do you have a image or PDF of the users guide or the install diagram?
Old Apr 6, 2008 | 05:01 PM
cbrguy7's Avatar
EDFC All time power supply (yellow wire):
Connect using a branch connector from the all time power supply.
EDFC accessory power supply (red wire):
connect using a branch connector from the accessory power supply having sufficient electric capacity such as a cigarette lighter.(in my case that would be to far away)
EDFC Illumination power supply (green wire):
connect using a branch connector from the illumination power supply..
EDFC ground (black wire):
Connect to a ground source.
I just dont know which wires to use under the dash..
Old Apr 6, 2008 | 06:27 PM
WLAURENT's Avatar
Use a multimeter or test light and find the wire that goes hot when you turn on the ignition (accessory power wire). For the illumination find a wire that goes hot when you turn on the dash lights.
Old Apr 6, 2008 | 06:32 PM
madkimchi's Avatar
i can't remember exactly which wires i tapped into but i used fuse box.
dirtYs2K
Sep 30, 2009 01:45 AM
rijowysock
Sep 11, 2009 06:09 PM
jwa4378
Sep 27, 2008 05:14 PM
Mr. Francesco
Mar 30, 2007 02:40 PM
rijowysock
Dec 8, 2005 09:01 AM
