Is there a DIY headunit install guide for the AP2?
Old May 1, 2010 | 10:53 AM
  #101
geoff2005's Avatar
is there a diy of installing aftermarket head units
Old May 19, 2010 | 03:52 AM
  #102
Push's Avatar
forgive me for this. but was it necessary to remove the center console?
Old May 19, 2010 | 04:50 AM
  #103
takeshi's Avatar
I've heard people (with AP2's) claim that they can remove the radio door and trim without removing the console. I've never been able to do so. It's not a big deal to remove. A dash removal tool helps but I've removed and reinstalled the console countless times without any tools.
Removal is covered on page 1. Install is a matter of getting a harness, wiring everything up properly and reversing the removal process.
Originally Posted by dapretendr,Mar 29 2010, 06:56 PM
Very good write up, any owner's recently updated their new HU? Can you recommend any good unit that in compatible with the modify DCI?
The list on their site are not current with all the new models that change every year.
From http://www.modifry.com/products/dci/...patibility.htm
[QUOTE]If you email me with a compatibility question I'm going to have to do my own on-line search to try and find the information so you're usually better off doing your own research.
Old May 19, 2010 | 04:51 AM
  #104
evil MS3's Avatar
Those with AP1s can remove the radio door without removing the center console.
Old May 24, 2010 | 06:35 PM
  #105
it'S2klean's Avatar
Just installed my very first head unit ever becuase of this FAQ. Thanks man!
Old Jun 11, 2010 | 04:44 PM
  #106
jazzy323f's Avatar
Originally Posted by ace123,Oct 14 2009, 11:03 PM
Notes:
- I didn't remove the shift knob or unplug the hazard/roof/etc; I just pulled everything back a bit and had enough clearance. It was really pretty easy that way, so I'd recommend tryin to skip that step on the original instructions.
Good info here for the guys. Did it this way tonight and it worked like a charm. Cheers.
Old Aug 4, 2010 | 09:37 PM
  #107
stonedS2000's Avatar
Anyone have some ideas (pics) on how to mount the cd player in place? I cant get the screws in when the cd player is in place, no room. JVC KD-AVX77.
Old Aug 5, 2010 | 12:09 AM
  #108
Juice Steez's Avatar
You need to drill new holes in the factory bracket to get the JVC KD-AVX77 to fit (I have the same HU). The door will also close when the screen is tilted at Lv. 2 if you get it right but will not close at Lv. 3 tilt. You also have to clear room behind the HU so that it fits with all the fixin' hooked up, try pulling the OEM Harness out from behing the drivers side to make some room.
Old Aug 14, 2010 | 10:06 AM
  #109
Drew523's Avatar
Installed a new headunit however, the spring loader for the cup holder fell off, anyone know how its suppose to go back on?
Old Aug 14, 2010 | 12:23 PM
  #110
BlackBearTX's Avatar
Ahaha I was reading this and was like lol wut? You have to take the center console off? Old post... I installed my Alpine 9886 only removing the door and plastic holding in the radio. The only hard and time consuming part was soldering connections for the head unit :S.
Adding an rca to 3.5mm jack was easy in the s2k, just goes through the dash to the floor since we don't have glove boxes there.
