Using stock Tweeters
Old Jun 9, 2003 | 07:46 PM
legendzzz's Avatar
Default Using stock Tweeters
Has anyone replaced just the front speakers and not the tweeters ?? From what I have heard the tweeters are a problem to replace and when replaced the highs are too bright! It may be best to keep the stock ones?
Old Jun 11, 2003 | 12:04 PM
Andy Kirk's Avatar
I left the stock tweeters in and also am running the co-axial tweeters in the new speakers. In my case as my hearing now cuts out at around 9k it isn't an issue.
By the time you are able to afford a really good system you no longer can appreciate it!
Andy
Old Jun 11, 2003 | 06:32 PM
ruexp67's Avatar
Can't you tweak the x-overs to make the tweets less bright?
Old Jun 11, 2003 | 06:37 PM
matrix's Avatar
Yes, a few ohm resistor will do this...
Old Jun 14, 2003 | 03:01 PM
legendzzz's Avatar
Andy I have polks in the rear and wanted to put EX3560 set in the front they have crossovers with them if I keep the original tweeters can I use the crossovers still?? or do the new tweeters make that much of a difference from the originals??
Old Jun 14, 2003 | 04:20 PM
ruexp67's Avatar
[QUOTE]Originally posted by legendzzz
[B]Andy I have polks in the rear and wanted to put EX3560 set in the front
Old Jun 14, 2003 | 04:49 PM
shockwave667's Avatar
I kept the stock tweeters, but rewired them to run off my amp. Sounds pretty good IMHO
xviper
Jan 1, 2005 11:05 AM
Ajjra
Jun 11, 2003 10:36 AM
PowerChord
Jul 4, 2002 11:34 PM
RayN
Apr 10, 2002 08:10 AM
gche37
Dec 31, 2001 05:50 AM
