anyone who has made a vertical amp mount going across the whole back wall of the trunk i need ur help.i am going to mount the 2 amps to it so i need the whole back wall dimension one. i jus want to make sure im getting the dimensions correct, they are 10.5 x 36i think ? how thick is the maximum it can be, and also how do i actually mount it to the back of the trunk?
I would use cardboard to make a template and then cust the board out to match it. Then just mount the amps right to it. You could use some small L brackets to hold it in place, maybe 1/2 board??
