Weakest Link?
Old Mar 2, 2004 | 09:35 PM
Silverstreak HX's Avatar
Default Weakest Link?
Hey just wondering what the weakest link is ? HU or the speakers??? Which one should you replace first???
Old Mar 3, 2004 | 08:45 AM
NFRs2000NYC's Avatar
Based on the Garbage in garbage out formula, the general rule is, you can have million dollar speakers that will reproduce crap really well. Basically, a good clear singal is first and foremost. They are hand in hand, but a HU is a must if you want good speakers, but good speakers are a waste with a stock HU. So the answer is head unit.
Old Mar 3, 2004 | 09:27 AM
R11's Avatar
R11
I seriously don't think the "specs" of the stock HU are as bad as most of you think in terms of distortion, S/N ratio etc (at least the '04 unit anyway). It's main drawback is just lack of decent power.
ron
Old Mar 3, 2004 | 09:53 AM
djweaver's Avatar
Depends on how you listen to your music.
If top-down, 85-90 mph - the volume level on stock HU will distort the he** out your speakers. Putting good speakers in will only cause you to distort the he** out of good speakers.
If top-up, 65mph - HU load will be low and better speakers will make a big listening difference IMO.
Old Mar 3, 2004 | 10:13 AM
[QUOTE]Originally posted by djweaver
Old Mar 3, 2004 | 10:33 AM
R11's Avatar
R11
If you decide to just add speakers, make sure you get efficient, high sensitivity speakers that are designed to run at lower power levels. Otherwise the volume levels will be even lower and you'll end up cranking it up into distortion just to hear them even when you're parked with the motor off .
ron
Greggs
Nov 21, 2009 11:24 AM
RL428
Nov 24, 2008 06:48 AM
qbmurderer13
Oct 30, 2008 06:53 AM
EDness
Jul 14, 2006 06:49 PM
jwocky
Mar 31, 2004 10:39 AM
