Weird..Revs drop every few secs with sub+amp [VID]
So I've found that if I have my sub and amp hooked up to my system when it's on the car's electricals (and idle) go whack, every few seconds the revs drop, lights dim, etc.
This is even with the volume muted.
If I disconnect the amp's remote turn-on, or if the system is off, everything's fine.
video:[media]http://www.youtube.com/watch?v=DwbwDe75UTs [/media]
what's going on?! the setup was all working fine for 4 months and now this has suddenly happened. grounds are ok, connections clean, fuses seem to be fine?
ideas?
ideas?
only thing i can think of is grounding issue or battery is about to die soon. I purchased a mazda 3 2 years ago. full decked out custom sound system. noticed i had the same problem. Threw in a capacitor... problem lessened. threw in a grounding kit from buddy club and everything is working fine. its my sister's car now and she hasn't had any problems with revs dropping.
Where are you grounding it to? bare metal or are you relying on a bolt as a ground?
Thanks for the reply
The battery is about 2 months old and the problem is the same after the change.
It's grounded to a bolt, but I sanded away the paint beneath the bolt for a better connection. Looks like I need to re-ground the damn thing. I'll try that.. thanks
Thanks for the helpful replies. Looks like a bad amp.
First I tried re-grounding by sanding a spot of paint/self tapping screw. Same problem. Then I swapped over the power and ground wires from the amp with those from my other amp (which has been working fine). The wire gauges and fuses are identical. Same problem again. This points the finger at the amp, yes? The fuses in the amp itself are fine too.
What can I do about this, is it really time for a new amp? This one's barely 18 months old.
not amp, per se, this happens when you are drawing more power than your alternator/power can provide without pulling from other areas, if it bothers you, add another battery and a higher output alternator
With system off it reads around 14.3V (if I remember right, but it's definitely 14+V), with system on it reads the same but everytime the revs dip the reading comes down to around 12.7V or so for a second before going back up to 14+V until the next rev dip.
Is this consistent with a not strong enough alternator?
