What could possibly went wrong ?
Old Jul 8, 2010 | 08:19 AM
RattleHead's Avatar
If your amp won't turn off then it would definitely drain your battery. Have your battery tested cause maybe it's going bad.
Old Jul 8, 2010 | 08:32 AM
Ryans2kGPW's Avatar
I already unhooked it so it won't drain my battery overnight. I only drive my S on the weekends that's why. Seems like if I leave it on for 8 hrs it's fine. But if I didn't drive it for 2 days then i will have to jump it =/
Old Jul 8, 2010 | 09:05 AM
Supra-holic's Avatar
To find out if it is the amp or not, reconnect your battery. Make sure your radio is off. If you amp is on, then disconnect the remote from the amp. If it turns off then your remote is live, if it doesn't then its the amp. I'm leaning torwards the remote wiring being live.
Old Jul 8, 2010 | 09:57 AM
Ryans2kGPW's Avatar
Did exactly what you suggested and ZING it's the remote wire that is live. So is it that my wiring behind the headunit is wrong ? I might have spliced a wrong wire ? Thanks
Old Jul 9, 2010 | 12:47 PM
Will's Avatar
Either you used the wrong wire from the headunit as the remote, or the headunit is sending a positive remote signal all the time (indicating a bad head unit).
Old Jul 14, 2010 | 04:46 PM
Ryans2kGPW's Avatar
Update !
I finally have a chance to open it up to take picture of my remote wiring.
Can someone point me to the right wire i should cut ? I did some researched before and they told me to cut solid blue/white wire. which is pictured here
Uploaded with ImageShack.us
Old Jul 14, 2010 | 06:25 PM
R3DS2K's Avatar
the wire you need is Blue with a white line not white with a blue line
i could be wrong as i dont see a blue with a white line
im not audio guy but i know a little bit and i think someone should confirm this but you might be able to just wire the solid blue to a red wire which is for ignition. which will only have power when key is on
Old Jul 14, 2010 | 09:09 PM
oth's Avatar
oth
If that's a picture of the connector on the car's harness, then the
white/blue wire you spliced is actually the constant +12v wire for
the headunit memory, not the remote turn-on, which would also
explain why your amp is always on.
The stock Honda radio has only a power antenna turn-on, which is
yellow/green in the car's harness. However, the Alpine almost
certainly has two separate wires for amp turn-on and power antenna,
and I would imagine that Modifry's PnP harness has both of those
wires, with the amp turn-on wire, probably blue with a white strip,
hanging loose waiting to be connected to an amp.
Old Jul 14, 2010 | 10:52 PM
Ryans2kGPW's Avatar
Thanks Ill try that tomorrow
Old Jul 14, 2010 | 10:54 PM
Ryans2kGPW's Avatar
Appreciate it. I will look into that tomorrow. Ill let you guys know if it works.
