what is the most efficient/sensitive component speakers?
Old May 20, 2001 | 05:41 PM
KaiWang's Avatar
Anyone know who makes the mose sensitive 2 way component speakers? Preferably something greater than or equal to 93db????
Thanks!
Old May 21, 2001 | 06:23 AM
MacGyver's Avatar
Wow, you get above 93-94 dB and we're talking some pretty sensitive speakers. I can't make any recommendations offhand, but I'm curious as to why you want such sensitive stuff?
Old May 21, 2001 | 06:43 AM
KaiWang's Avatar
Well, I will be running the speakers with the stock head unit for a while, so the more sensitive speakers I get, the better...
Currently Im looking at the Focal Polyflex 165 H 2 way components (92.5 db)
Old May 21, 2001 | 06:48 AM
cbj's Avatar
cbj
I'm in the same situation. Want to upgrade from stock to components- but it will be awhile before I upgrade the head unit. Interested to see what you find out.
Old May 21, 2001 | 06:13 PM
WestSideBilly's Avatar
Blaupunkt Overdrive Series ODc65 are rated at 93 dB (no clue on sound quality though). Typical for a 6 1/2" component is 90-91 dB, as you probably found.
A 0.5 dB difference is barely perceptible to the ear, so you should consider sound quality before searching for an extra 0.5 dB of sensitivity. Also, the stock head unit amp probably can't push any speakers, even 93dB rated ones, past 105 dB or so without major distortion. Save your pennies for a while and get an amp right away if you really want the volume needed for high speed cruising. A good solution might be to hunt down a "cheap" 30x2 and wire it at the same time as you do your speakers, then swap amps for a good 50x2 (or whatever you want) when you have the $$$.
Old May 23, 2001 | 10:23 AM
koejing's Avatar
Check these mobile HLCD speakers:
http://www.imagedynamicsusa.com/products/horns.html
Sensitivity ranges from 97dB to 109dB depending on the model.
-koejing
Old May 23, 2001 | 10:39 AM
MacGyver's Avatar
The disadvantage to these (other than the size for the bigger models) is they are only mid- and high-range components...you would still need an efficient low-range speaker.
Old May 23, 2001 | 11:04 AM
Schatten's Avatar
they would be pretty interesting for tweeters though! just no place to mount them. at the smallest size, approx 5" x 2.5" space. creative ideas?
Old May 23, 2001 | 11:44 AM
koejing's Avatar
Mac,
Low range HDLC's do exist, but size usually restricts them to home audio apps. They work great with low power tube amps.
-koejing
clarence35
Jul 9, 2007 07:47 AM
clawhammer
Jun 17, 2006 05:47 PM
Mike in Atlanta
Sep 2, 2004 11:47 AM
S2000 0E
May 5, 2004 08:03 AM
ImportSport
Feb 22, 2004 11:35 AM
