Where to buy stock speakers?
Old Sep 6, 2007 | 04:38 PM
zoomkat's Avatar
I had a bad driver's side speaker and had it replaced under warranty. They said they would only replace it once.
Old Sep 6, 2007 | 06:06 PM
globallyoff's Avatar
I have some stock speakers I'll sell you from my MY05. PM me if you're interested.
Old Sep 6, 2007 | 06:52 PM
leo520's Avatar
I have a pair stock speakers and tweeters from my 07 , with just a few hundred miles then i changed out, PM me if u intrest.
Old Oct 7, 2007 | 11:34 PM
broken j o e y's Avatar
Your speaker may not be blown. If you pull the speaker out, and look closely at the face of it, there is a cardboard ring which is actually the outer edge of the speaker attached to the suspension part of the speaker cone. It is glued to the metal frame of the speaker. Part of mine came unglued and was vibrating like Hell sounding just like a blown out speaker. To find out if thats your problem turn the bass up all the way, and adjust the stereo balance to the side thats vibrating. While playing something with heavy bass. Take your finger and press down on the loose/unglued cardboard, and you'll know right away if thats the problem or not. Other than the glue the only thing that holds the cardboard down are the 3 mounting screws. If you turn the speaker around to the back side you'll notice that there are three more holes in the metal part of the speaker frame that are covered up by the cardboard that aren't being used. Solution: purchase 6, 6-32 x .250 screws, 6, 6-32 nuts, and 6 #6 flat washers. You can punch out the holes in the cardboard, and install 3 screws, nuts, and washers in each speaker, and the cardboard will be permanetly attached for life without any more vibration/blown speaker sounds. I tend to think it's probably a common problem with all 06/07 oem speakers. Let me know if that helps, Good luck!
Old Oct 8, 2007 | 12:07 AM
CKit's Avatar
www.crutchfield.com
I love my Ipod integration and a HU with some power.
Really easy to install. Door speakers, too.
Old Oct 8, 2007 | 02:28 AM
slipper's Avatar
I wouldnt install aftermarket unless your palnnign on replacing everything and installing a sub. Aftermarket speakers with OEM deck sound worse than stock speakers.
hansai00
Aug 29, 2008 06:45 PM
EDness
Jul 14, 2006 06:49 PM
Bibbs
Jul 11, 2006 05:00 AM
YOD88
Apr 10, 2004 07:11 PM
Tox
Aug 30, 2001 02:58 PM
