Where to go through the firewall?
When running your power wire to the battery where did you guys go through the firewall at? I went through the passenger side foot well, through an existing hole. It was the one that what appeared to be a hose came through. The hose went to the bottom of the dash and opened up into the dash(not sure what this is). THe hole came out down below where the headers are I ran it up along the firewall and then to the battery. Is this a good place to have it????
Second question about crossovers in the doors. i mounted them towards the back inside that little cup thing, is that alright?
Any info would be great
i put my crossovers in the door as well. near the rear of the panel. no problems.
the power wire i ran near the clutch pedal. i drilled a hole.
many people here run it through the main engine harness grommet on the driver side
