Where to go through the firewall?
Old Dec 19, 2005 | 09:38 AM
s2kmaniac81's Avatar
Default Where to go through the firewall?
When running your power wire to the battery where did you guys go through the firewall at? I went through the passenger side foot well, through an existing hole. It was the one that what appeared to be a hose came through. The hose went to the bottom of the dash and opened up into the dash(not sure what this is). THe hole came out down below where the headers are I ran it up along the firewall and then to the battery. Is this a good place to have it????
Second question about crossovers in the doors. i mounted them towards the back inside that little cup thing, is that alright?
Any info would be great
Old Dec 19, 2005 | 10:00 AM
boyguan's Avatar
i put my crossovers in the door as well. near the rear of the panel. no problems.
the power wire i ran near the clutch pedal. i drilled a hole.
many people here run it through the main engine harness grommet on the driver side
Old Dec 19, 2005 | 10:47 AM
j_c_a's Avatar
There's also a nice grommet right behind the battery you can use.
Old Dec 19, 2005 | 11:12 AM
JawKnee's Avatar
Yup, that's what I used.
Remove the battery and you will see it.
Old Dec 19, 2005 | 11:27 AM
jasonw's Avatar
Old Dec 19, 2005 | 01:24 PM
99SH's Avatar
When u guys run the wire, which side do you fish the wire through? Push wire from engine bay to cabin? or pull wire from cabin to engine bay?
Old Dec 19, 2005 | 01:25 PM
jasonw's Avatar
bay to cabin
Old Dec 19, 2005 | 01:32 PM
Saki GT's Avatar
Just in case you don't know, if you put the crossovers in the door, wrap them in something to absorb the shock from closing and keep rattles down.
Old Dec 19, 2005 | 02:29 PM
thanks for the info guys. I actually removed the power wire and put it throught the hole you guy suggested. Saki what do you recommend I wrap them in?
Old Dec 20, 2005 | 04:51 AM
j_c_a's Avatar
I'm actually not a big fan of crossovers in the doors. I know a lot of folks do it w/o issues, but i just don't like the idea of them being jarred every time the doors are closed.
My $.02
