Where to have AMP Repaired?
Old May 4, 2007 | 08:57 PM
NVMY4N's Avatar
Default Where to have AMP Repaired?
I have a spare RF BD500.1 it's an old amp that I bought for nearly nothing, that is identical to one I have in my DD.
So I let a friend borrow it, and he brings it back all Fd Up. Some Friend.
So it's been in the box for a while and I'd like to possibly get some use out of it.
Problem:
The Allen Screw for the GD- is cross threaded in the ...."reciptical"
So I took off the bottom plate to see if I could remove the entire thing......and buy a replacement, but Id rather let someone that knows what they are doing mess with it.
I know this will probably need pics.....but thought Id see if anyone knew a fix or where to send it w/o much hassle.
This is an AMP thats like the one I have, in case any of you had this back in the day.
This thing is pretty old, the one I have in the car now - I bought it brand new in 2002-2003 I think. just pushing 1 - 12" RF-HX2
Old May 4, 2007 | 09:03 PM
Will's Avatar
if a cross-thread is the only problem, you could probably fix it for a few bucks... just drill into the cross-threaded allen bolt, use an easy-out to remove the bolt, tap the hole with a slightly larger thread pattern, and use a new allen bolt (or whatever head you want really) that matches the new thread pattern. Voila. $0.50 for the new bolt if you already have a drill, bit, and tap & die set... or just pay for the tools.
Old May 4, 2007 | 09:07 PM
NVMY4N's Avatar
Well I guess I could......not really too keen on taking a drill to it. But WCS ....
Old May 5, 2007 | 12:23 PM
listener's Avatar
You could try tapping it, but you must be cautious not to torque the connector too much and damage the PC board.
Call Rockford at 800-366-2349 and have them quote a repair. Last I heard they have a flat rate depending on model. That amp isn't too old, so hopefully they have parts.
Old May 7, 2007 | 02:43 PM
NVMY4N's Avatar
cool thanks
kw_21
Sep 20, 2018 12:28 PM
m1sterlaw
Apr 20, 2010 03:57 AM
Quick Silver
Dec 10, 2006 08:32 PM
bon2k
Nov 25, 2003 09:22 PM
