where to tap for power
Old Jan 11, 2011 | 10:43 AM
street_ruler's Avatar
Default where to tap for power
Hey im installing a hard wire kit for my escort passport and i want to know where i should tap for power. Im looking for somplace i can use that is either a "signal" wire for a relay or that is key-on powered only.
got any suggestions?
Old Jan 11, 2011 | 10:47 AM
2003AP1's Avatar
12 volt power socket?
Old Jan 11, 2011 | 10:51 AM
thats actually not a bad idea.
i was hoping for something more in the forward part of the cabin as i want the mount it just under the rear view mirror and then run the wires through the top of the windshield trim and then down. kinda "hide" the wires.
Old Jan 11, 2011 | 10:52 AM
ViperASR's Avatar
Back of the radio. There is a wire that is only "hot" when the ignition is on. This is what I have my V1 hardwired to.
Use a voltmeter to find it, I can't remember what color it is off the top of my head.
Edit:
I did exactly what you wanted to do. I pulled off the passnger side windshield plastic trim stuff, ran the wire behind that, ran it under the dashboard tucked up where it isn't going anywhere, and then behind the radio. Its a very very simple install and all wires are hidden.
Shoot me a PM if you have any questions.
Old Jan 11, 2011 | 10:55 AM
hypforlife32's Avatar
there is a spot on the fuze panel that is hot with ignition and the ground wire is right there as well. i forget which one is exactly is but there is 3 prongs there. one is aways hot and on is hot with ignition.
Old Jan 11, 2011 | 11:34 AM
Moddiction's Avatar
Former Sponsor
Right in the fuse box in the cabin by your foot. There are a few available fuse spots that are only on with power. Just check them with a volt meter on and off to make sure. Mine is wired in there.
Old Jan 11, 2011 | 02:17 PM
chViETnk's Avatar
this should help
https://www.s2ki.com/forums/index.php?showt...&#entry10847685
Old Jan 11, 2011 | 03:40 PM
CapoArgentino's Avatar
Banned
^^ On that same fuse box there are 3 free male connectors. One is 12V continuous, another is 12V parking lights and the 3rd one is Acc 12V.
Old Jan 11, 2011 | 05:51 PM
iDashX's Avatar
I believe the 3rd 12V is when the key is in the ON position not ACC.
I install my friend's escort tapping the 12v on.
Old Jan 11, 2011 | 06:17 PM
Banned
^^ Correct
Thanks
