Where is your crossover?
Old Aug 1, 2006 | 06:08 PM
TOYCLOSER's Avatar
Default Where is your crossover?
I put my crossover in the little black box on the door panel; however a diode came loose on just the first day out (I resodered it already). Is this gonna be a constant problem from closing the door or you think it was just a faulty diode? (polk db6500)
Old Aug 1, 2006 | 06:10 PM
koala's Avatar
I have the db6500's as well... I mounted the crossovers inside the hollow black plastic areas near the back of the door panels.
I used double-sided tape and screws... I had to remove the panels after the first couple of days to basically just re-adjust everything... but since then they've been solid.
Old Aug 1, 2006 | 06:16 PM
TOYCLOSER's Avatar
i'm using velcro myself
Old Aug 1, 2006 | 06:35 PM
koala's Avatar
It's all about the screws... I tried just double sided tape originally and it didn't work very well
Old Aug 1, 2006 | 07:33 PM
globallyoff's Avatar
I have db 6500 myself. I drilled some small holes in the black plastic thingys and screwed the crossovers in. No issues yet.
Old Aug 1, 2006 | 08:21 PM
Saki GT's Avatar
I put mine in the trunk. I wasn't to fond of the idea of them being in the doors if I ever wanted to tweak them, and I didn't like the idea of rattling them around everytime a door was shut.
Old Aug 2, 2006 | 03:41 AM
TOYCLOSER's Avatar
Unhappy
Originally Posted by Saki GT,Aug 1 2006, 08:21 PM
I put mine in the trunk. I didn't like the idea of rattling them around everytime a door was shut.
That is what has me concerned
Old Aug 2, 2006 | 08:19 AM
koala's Avatar
I had some spare time last night so I removed my door panels to see how the crossovers are holding up... they're still solid after almost a year of being in there.
All I did was put double-sided tape on the back of them to cut down on vibrations and noise (if any), and then took two small screws and screwed them in place with the two holes already in the crossovers for such a purpose.
It works just fine... the only small issue I have is that the speaker wire provided with the polk speakers is just a touch too short to allow me to sit the door panel on the ground when working on it, so I have to put something under my door to rest it on.
Old Aug 2, 2006 | 07:52 PM
s2kheat's Avatar
Sorry to jack your thread.
For those who have the Polk DB6500's how do you like them? Did you have to use spacers to clear the windows?
Did you use the existing tweeter holes to mount the new ones? What if any mods did you have to do to the tweeters fit?
Old Aug 2, 2006 | 08:24 PM
revhi's Avatar
Mines in the doors as well for now, I am going to relocate to the trunk soon for easier adjustments.
As for the tweeters, not Polk, but factory location.
