Who has tackled fiberglass work?
Old Jul 18, 2007 | 01:25 PM
WLAURENT's Avatar
Make sure you also wear a mask when working with the glass (cutting or laying up). You do not want any powder or glass fiber getting into your lungs or sinus'
You can buy 1/4 sheets of MDF at most lumber yards - make your own speaker ring, the fit will be much better that getting a generic ring (10" subs vary from 8.7" cut-outs to 9.5" cutouts).
I would recommend that you get your resin and glass from either west marine or HD/Lowes. Just make sure that it is not old (typically resin only has a shelf life of about 1 year max). This will work fine for doing a one-off enclosure since you are not concerned with how it kicks or releases. If you are doing production stuff using molds - then you would want to buy higher quality resins.
http://www.westmarine.com
You will also not need any mold release if you are making a one-off enclosure.
Old Aug 6, 2007 | 09:02 PM
DDuds2k's Avatar
can you clarify what a "one-off" enclosure is. thanks
Old Aug 6, 2007 | 09:12 PM
WLAURENT's Avatar
Only building one. If you are mass producing you will need to make a mold, which requires a plug or reference part which you make the mold from. You would need mold release in order to get the parts to release from the mold.
If you are building one you will likely not need to make a mold.
Old Aug 6, 2007 | 09:23 PM
DDuds2k's Avatar
cool thanks. mark that item off my list.
corbzin
Dec 2, 2009 03:07 PM
shotgunjimmy
Jul 7, 2008 07:22 AM
Will
Nov 11, 2007 09:58 AM
southkhaki19
Sep 8, 2006 05:55 PM
darkknight1999
May 10, 2005 02:18 PM
