Why so many Watts?
Old Jun 15, 2011 | 10:15 AM
cvjoint's Avatar
Originally Posted by lovegroova
Originally Posted by cvjoint' timestamp='1307726471' post='20669767
[quote name='lovegroova' timestamp='1307698642' post='20668443']
Wow, was that with the fan switched to maximum and the recirculate button on?
Yep. It's 92db with the A/C off and idling. The microphone is calibrated and I don't use any weighing method either so it's very accurate.
I'm a bit puzzled by your figures. I did a quick check last night, and my car was 55dB. Admittedly, I used my phone (set to "slow"), but it's pretty close to my sound meter.
Were you holding the sound meter, or was it resting on the centre tunnel or dashboard?
FWIW measured 35dB engine off, then 55dB engine on, and 100dB sound system on high, but not maximum, volume.
[/quote]
I held the mic in my hand, close to ear level. The measurement system is a Dayton Omnimic. It's made by Praxis, basically the Mercedes of measurement systems.
Your phone mic is an awful tool. I tried my Droid with various apps. and if fails badly. The mic clips really easy and has a very irregular response under 100hz. Lastly, it may be A-weighted. If I use A-weights like car magazines do I get very close to their published numbers.
For the purposes of car audio background noise checks you don't want to use weights. This car has loads of noise with the engine on at 30hz. It may be that's where the resonators are tuned from the exhaust or simply a cabin gain effect.
Old Jun 15, 2011 | 05:10 PM
oth's Avatar
oth
I'm the first to admit that I know nothing about sound levels, but everything I've
read lists sounds at 90+ dB as quite loud and very annoying, not how I would
describe my s2000 at idle.
For instance, the chart here gives the following examples (their comments):
  • Jet Flyover (1000 ft.) 103 dB
  • Garbage Truck/Cement Mixer 100 dB (No more than 15 minutes of unprotected exposure recommended for sounds between 90–100 dB.)
  • Farm Tractor 98 dB
  • Newspaper Press 97 dB
  • Subway, Motorcycle (25 ft.) 88 dB (Very annoying)
  • Lawnmower, Food Blender 85–90 dB (85 dB is the level at which hearing damage (8 hrs.) begins)
  • Diesel Truck (40 mph, 50 ft.) 84 dB
Old Jun 15, 2011 | 06:32 PM
cvjoint's Avatar
Yes, A-weighted. Most of the SPL in the S2k comes for frequencies under 100hz. 90db at 30hz is nowhere near as annoying as 90db at 2000hz. OSHA rates SPL A-weighted, it basically gives bass frequencies a lower weight.
Old Jun 20, 2011 | 05:50 AM
lovegroova's Avatar
Originally Posted by lovegroova' timestamp='1308144328' post='20684381
[quote name='cvjoint' timestamp='1307726471' post='20669767']
[/quote]
[/quote]
I realise the phone is not great. I wouldn't describe it as "awful", as it gives a pretty good approximation, especially when considered in line with oth's post and the comparatives posted there.
Can you do a C-weighted measurement, as I guess that's probably the best approximation to the human ear (especially my 42 year old examples!) widely available?
Really interesting stuff though
Old Jun 20, 2011 | 09:43 AM
cvjoint's Avatar
I can do A and C weights. I forgot one thing. I took my rear tray out. Even though I have I layer of Dynamat Extreme on it and 1" of open cell foam, odds are I don't do as good of a job absorbing as the rear tray.
I can post full FFT or RTA graphs of background noise with the engine running. Stick around.
Old Jun 21, 2011 | 05:01 AM
lovegroova's Avatar
Brilliant. I'll keep an eye on this thread, and might even get my sound meter out to the car to do some c-weighted testing.
Old Jun 23, 2011 | 01:07 AM
cvjoint's Avatar
Without any weights this is what the noise spectrum looks like with the engine on:
This FFT plot tells the whole story imo. There is lots of engine noise at 27hz or so. That's what's driving the high background noise readings. They were all about 96db this time with the engine warmed up and 90db right when I started. Using the C-weight only brought it down a db or so, same for A-weight.
I now have the air box lid off as well. Add in the rear tray is out my car is a bit louder than stock. However, it's all driven by that bassy peak. That's why it is not annoying. Heck, some old guys probably can't even hear it. Over 100hz where our ear starts gaining some sensitivity the noise levels are well bellow 70db.
Here's what it looks like driving, 1st gear 8,000rpm:
There is a lot more low midrange growl, notice a different higher peak at 280hz. That's quite dangerous if exposed for a long period of time!
Old Jun 23, 2011 | 03:15 AM
lovegroova's Avatar
Very cool!
Would I be correct in saying that the very high readings at low frequencies are less of a problem for the human ear, which doesn't hear them very well?
Old Jun 23, 2011 | 09:42 AM
cvjoint's Avatar
Yeah, you'd be correct. In hearing tests they never even test those low frequencies. Check out the equal loudness curve:
http://en.wikipedia.org/wiki/Equal_loudness_curve
Something at 27hz has to be 30db louder, many many times over for it to sound as loud as 1,000hz.
Also, if I were to guess that's what resonators do. They take away noise from a wide bandwidth where it would be annoying and concentrated outside of our hearing range, or close to it. My best guess is the OEM cans concentrate all the exhaust noise around 27hz.
DVSwetwilly
Aug 4, 2006 09:29 AM
scho01
Mar 27, 2006 01:04 PM
Xistence
Apr 12, 2005 10:24 AM
highrev
Oct 25, 2003 05:53 PM
j_c_a
Apr 1, 2003 11:04 AM
