Wiper click?
Old May 6, 2003 | 05:29 AM
Sbeall's Avatar
Default Wiper click?
I just picked up an '01 S2000 with 12,000 miles. Everything seems fine except there is an electronic click every time the windshield wipers move. Since I've never driven another S, I hope this isn't normal.
It only happens on the slow setting and is the same click that the turn signal / hazards use. The car has an after market alarm installed, so I'm thinking there's something crossed with the wiring.
Old May 6, 2003 | 05:36 AM
1a-race's Avatar
Banned
mine does it on the low setting
Old May 6, 2003 | 08:07 AM
Sbeall's Avatar
So that's normal? It's kind of annoying.
Old May 6, 2003 | 08:16 AM
1a-race's Avatar
Banned
Don't know. Turn your radio up.
Old May 6, 2003 | 08:18 AM
lanbrown's Avatar
Yes it is normal. I personally think Honda should have put intermittent wipers on the car. It would have at most added a minimal amount of weight.
Lance
Old May 6, 2003 | 09:38 AM
Sbeall's Avatar
Why would they intentionally have a click sound associated with the wipers? Now I have to get rid of it (the sound not the car).
Old May 6, 2003 | 10:01 AM
lanbrown's Avatar
It isn't intentional as they are using a mechanical relay, which makes the clicking noise. Some newer turn signals are microprocessor based and thus not mechanical and no click. The advantage to these is that they provide a consistent flash without depending on the load. Some cars have their relays buried deep inside the car and then you can't hear them. Honda made the decision to use a mechanical relay and it is not covered with various components of the car.
If it bothers you so much, try to find an electronic relay and see if it will run the wipers at an equivalent speed.
Lance
Old May 6, 2003 | 11:02 AM
modifry's Avatar
Honorary Member
Originally posted by lanbrown
. . . If it bothers you so much, try to find an electronic relay and see if it will run the wipers at an equivalent speed.
Lance
If you find an electronic substitute, let me know. It has to act like a true relay, conducting current in both directions, and have SPDT functions. So that's at least 4 high-current FET's and associated circuitry to drive them, which means you need a separate power supply connection in addition to the normal relay connectors.
I made one for my car because of the annoying clicking, but it's not pretty, or cheap.
I've often thought of making an add-on controller for the intermittents, one with speed-sensitive wiper timing, but I only think about it when it's raining.
Old May 6, 2003 | 11:10 AM
The Gasman's Avatar
The click is annoying, but is only audible to me at the delay setting. It's not annoying enough IMO to do something about.
Old May 6, 2003 | 11:14 AM
rateds2k's Avatar
You could always take off the wipers and use Rain X.
