Wired DCI Question
Old Feb 18, 2007 | 12:06 PM
Kodokan_4's Avatar
Default Wired DCI Question
I purchased Modifry's Wired DCI for a Sony HU and there is a LONG green wire coming out of the connector that plugs into the HU. (This wire is probably 4 ft long; the other wires are a few inches.) There is a label on the wire that says "PARKING BRAKE".
I've looked through all of the instructions, and I don't see this wire on any of the DCI schematics, or described anywhere in the instructions.
I assume that I should splice the wire into one of the parking brake wires, but my question is - what does this wire do, and does it have to be connected? (For example, I'm not going to use the Speed Volume Control feature, so I don't need to connect the gray wire.)
My best guess is that it's a wire that is hot only when the accessories are on, but I think there is already a green wire in the harness that does that.
-Pete
Old Feb 18, 2007 | 09:43 PM
Kodokan_4's Avatar
Figured it out. The wire is part of the HU, not the DCI.
Sony has a lockout on the screen, so you can't play video unless the parking brake is on.
I'm wondering if I can attach this wire to a positive lead that is hot when the accessories are switched on. Then, video should play all the time. (I hope.)
-Pete
Old Feb 19, 2007 | 05:00 AM
darkknight1999's Avatar
Most people here Pete probably won't tell you how to by-pass it... I won't either. Its there for your safety... but you can look it up on google.
Old Feb 19, 2007 | 07:45 AM
nearwater4me's Avatar
I think you have to GROUND the wire.
I have an AVIC-D1 that disables Nav functions, video playback while the vehicle's running, and I grounded the parking brake wire to make them functional all the time.
Dan
Old Feb 20, 2007 | 06:04 PM
Kodokan_4's Avatar
Luckily, I only had to ground the wire.
Evidently, some HUs need a switch on the ground wire, but my Sony didn't.
That makes the install easier, and the video screen works all the time.
I don't want to watch the screen while I'm driving, but I don't want to (have to) put the hand brake, either.
Thanks to all for the info!
-Pete
s20001988
Apr 20, 2012 10:23 PM
CarmenOhio
Mar 20, 2006 05:18 AM
kev1025
May 19, 2005 09:16 PM
ruexp67
Jun 20, 2003 09:45 AM
S2WOOOW
Dec 19, 2002 01:39 PM
