Wiring your S2000's new ICE setup
Oh yeah and don't forget to upgrade the fuse that you have next to the battery
you should have a 60amp fuse or even maybe a 70 amper in there for both amps what ever your amp company recommends for each amp.
you should have a 60amp fuse or even maybe a 70 amper in there for both amps what ever your amp company recommends for each amp.Darkknight, I also have a couple of hopefully quick questions about those two grounding points in the trunk. Do you happen to know the bolt sizes? Aren't they metric? I have some 5/16" and 7/16" ring terminals I'd like to use. Will either fit?
I also noticed the body beneath those bolts is painted. I guess that means I have some scraping/sanding to do, right?
Thanks.
Originally Posted by darkknight1999,Dec 29 2004, 08:26 AM
Actually you'll be just fine with that 4 gauge lead off the battery running to a fused distribution block in your trunk. Your honestly not running enough to warrant a 1/O cable, unless you want to. But just don't think you don't 'have to' because it would be overkill.
Just get a "fused" distribution block like Farkey said. Run your 4 gauge to that and split it into to 6 or 8 gauge cables, then run those to your amps and you'll be just fine. Just make sure you get a fused block
Nothing...
I'm a big fan of overkill... I think everyone here knows that
however I just don't want him to feel like he "has to" buy new power wire. He can just split the 4 gauge to save the money if he wanted to
Originally Posted by darkknight1999,Dec 29 2004, 12:17 PM
Nothing...
[QUOTE=MacGyver,Nov 12 2004, 06:58 PM] Also, high up on the firewall behind the battery is a grommet that leads into the windshield wiper mechanical area... I run wires into that grommet, along the top of the firewall (zip tie stuff away form the wiper mechanics and motor), back out a similar grommet on the driver's side firewall, down the firewall, then into the grommet mentioned earlier by the clutch pedal.
Remove the windshield wipers (just unscrew the nuts on top with a ratchet), remove the rubber strip along the inside of the engine bay, remove the 7 clips just under the rubber strip, then pull.
