XM Digital Adapter for Alpine
Old Feb 25, 2008 | 01:09 PM
BerlinaBK's Avatar
Default XM Digital Adapter for Alpine
Does anyone have any experience with the Terk XM Smart Digital Adapter for Alpine radios (CDA-9830 in my case) and the XM Direct Universal Tuner Box? I installed everything yesterday, verified my service and everything was golden for about 12 hours. I then turned my car on to leave for work and my XM wouldn't play, I cycled through the different input sources on the headunit (Disk, radio, etc..) and now my headunit will not recognize that I even have XM. I would imagine this narrows my problem down pre-headunit, a.k.a the digital adapter. I pulled everything, checked the connections and it seems fine. I checked online, went to Best Buy and I can no longer find this kit (or any other in-line Alpine kit for that matter). I still need to check the voltage at the connection, but I was wondering if anyone had a similar experience, or any suggestions for me. Thanks in advance!
Old Feb 25, 2008 | 04:04 PM
imdarkrider's Avatar
check the fuse that's in noise filter going into the XM box, those blow sometimes for no reason.
Old Feb 28, 2008 | 06:48 PM
BerlinaBK's Avatar
Hmm, unless its in the XM box itself, there is no in line fuse Ill open up the box itself in the morning and see.
Old Feb 28, 2008 | 06:49 PM
no there's not fuse inside the box .... it's weird that yours didn't have a noise filter (those have the fuses inside of them, it's a little black box) otherwise , unhook the cable from the XM box , then plug it back in and turn on the car and see what happens.
Old Feb 28, 2008 | 06:54 PM
BerlinaBK's Avatar
Yeah I tried that too. I actually pulled all the wiring, checked all the connections and reset the headunit... still no XM. This is the digital xm kit thats controlled from the headunit, maybe thats why I don't have the Noise filter.
Old Feb 29, 2008 | 05:04 AM
I know which one your talking about and that's werid that it doesn't have it.... I dunno i'm lost for ideas unless you know how to use a multimeter to see if the pins are getting power correctly
Old Feb 29, 2008 | 06:18 AM
BerlinaBK's Avatar
I do, and I searched my toolbox but mine has gone MIA haha Im gonna look for it now and see if I can narrow down the problem. I opened up both boxes, and I dont see any loose or scorched components on the boards. Im wondering if its a break in the wiring. its just odd that it would stop working so abruptly.
Old May 29, 2008 | 07:06 AM
nuklearmaniac86's Avatar
Did you ever find the solution? I had my xm go out on me also in about a month. i think it's the XM Direct Smart Digital Adapter because it smelled like it fried. I put it next to the transmission tunnel (under the carpet under passenger net) and almost positive it overheateated.
HiVolume
Jun 13, 2010 07:13 PM
wasupdu
Mar 14, 2007 08:42 PM
superjimbo
Oct 5, 2005 12:52 PM
pikkashoe
Oct 29, 2004 02:36 PM
Casas
Aug 8, 2003 05:33 AM
