yellow box install
Old Jan 13, 2006 | 03:54 PM
news2kroller's Avatar
Default yellow box install
i know that the yellow box requires a 11% change from stock, however with the tires i have should i change that 11% to something else? my tires are 245/40/17 also if somone has a write-up of the yellow box install with pics that would be great. thanks.
Old Jan 13, 2006 | 05:38 PM
xviper's Avatar
Since you didn't mention it, I assume that you're talking about 4.56 gears (which would be 11.2% by themselves). Those tires you are using would only introduce about a 0.3 mph (or less) difference at about 150 mph. This is not enough to worry about. You will have a bigger error just from the natural OEM speedo error, which has been determined to be anything from dead on to 2%. If you truly want a perfectly accurate speedometer, you'll need to get paced by a known calibrated source like a police car, mileage test markers on the highway, etc. Then you calculate the % error and dial that into the YB.
Old Jan 13, 2006 | 07:43 PM
jah's Avatar
jah
use the mile markers, method given in the yello box instructions. be done with it.
i didnt think there was that much err (2%) in the oem digital driven system but 2% is very small.
Old Jan 13, 2006 | 07:59 PM
xviper's Avatar
2% is about the max I've heard of. Like I said, most S2000's are "dead on".
Old Jan 14, 2006 | 08:36 AM
thanks for the input guys.
MajorHavoc
Aug 3, 2016 05:45 PM
le do
Mar 18, 2016 02:34 AM
ap1son
Oct 17, 2008 04:45 PM
np2k1s2k
South Florida
Sep 21, 2006 03:54 PM
Fyrestrike
Feb 20, 2004 12:09 PM
