02 s2k on kpro with rsx ecu?
Old May 14, 2010 | 03:03 PM
Crisgo's Avatar
Default 02 s2k on kpro with rsx ecu?
I was told on a earlier s2k mine is a 02 that you can run kpro with a base rsx as long as it is a manual trans. Can someone confirm this for me. Came from a reputable source. I know that the a01-012 ecu will work but those are type-s'. Thanks
Old May 15, 2010 | 06:25 AM
nnausmann's Avatar
Base rsx ecu will not work.
"The S2000 KPro includes a new or user supplied RSX (PRB) ECU adapted for the S2000, and a wiring harness for the crank and cam sensors. It does not include the Honda parts - see Mechanical Modifications below. All user supplied ecu's must be PRB A01-A12 and in perfect working order. We will not use any other ecu's for the S2000."
http://www.hondata.com/s2000kpro.html
taylor
Aug 20, 2011 03:49 AM
BerlinaS2Kyle
Nov 29, 2009 09:24 PM
macspeed704
Nov 5, 2005 06:56 AM
SC-SUZUKA
Nov 8, 2002 04:47 PM
