06+ Running aem v2
Old Mar 4, 2016 | 08:11 AM
liquidgsr's Avatar
Default 06+ Running aem v2
Is anyone running AEM V2 on there 06+. I have my brake light, VSA, ABS, and light next to VSA on. I am wondering if it is because of the AEM. Any help?
Old Mar 4, 2016 | 11:35 AM
dv55xc's Avatar
Any reason why you went with ems vs a flash pro?
Old Mar 4, 2016 | 12:04 PM
liquidgsr's Avatar
Flex fuel mainly and switching from low to high boost settings. I actually have both, but need to have a retune.
Old Mar 5, 2016 | 08:31 PM
Szoylent Green's Avatar
Does the AEM work with the DBW and VSA?
So it has a CAN bus interface?
Old Mar 6, 2016 | 05:14 AM
Chuck S's Avatar
There is no OBD2 port on these (or I'm looking at the wrong item). No OBD2 means these will never pass smog testing.
There's a piggy-back fuel/ignition module that may work with the OEM ECU.
Lack of flex-fuel sensing in the original cars and ECU is a limiting factor in what I suspect are tiny segments of the market. But important to those segments.
-- Chuck
Old Mar 6, 2016 | 06:02 AM
liquidgsr's Avatar
If Hondata had a flex fuel option I would ditch the Aem in a heartbeat.
Old Mar 6, 2016 | 06:35 AM
Jin_SK's Avatar
-- Chuck
06+ AEM Series 2 is a dual ECU and keeps OBDII. KPRO4 is also capable for 00-05.
liquidgsr
Mar 5, 2016 12:51 PM
liquidgsr
Jan 24, 2016 07:32 PM
Splunkery
Apr 17, 2015 01:17 PM
leftyz
Mar 27, 2013 04:51 PM
