2006+ readiness not setting flashpro
After thinking about this statement, I realized that it was a mistake. Once I got the tune dialed in, I was able to complete readiness very easily with my S2000, but I have a climate controlled garage. It would probably be harder to get them to complete if the car started out at different temps.
Originally Posted by Gernby' timestamp='1447104576' post='23799213
Did you datalog it? If it doesn't set in the first 10 minutes of driving after a cold start, then there is either something wrong with your process, or there's something up with the tune or car.
Anyhow, hopefully my experience helps some others with their issues. I will say that verifying that you have a good tune with the correct parameters makes all the difference. Thanks again to Greg and the others who helped troubleshoot the issue.
I never could get mine to clear. Wadzii put a 1,000 miles on my car without getting them to work. Supposedly did all of the above and more, change O2 sensors, put cheaters in, nothing. Ended up selling the Hondata and bought a Ktuner. Car is running fine now so I cannot complain.
I never could get mine to clear. Wadzii put a 1,000 miles on my car without getting them to work. Supposedly did all of the above and more, change O2 sensors, put cheaters in, nothing. Says he taught Gernby everything he knows and therefore to proud to ask his help. Ended up selling the Hondata and bought a Ktuner. Car is running fine now so I cannot complain.
Btw, I ran into an issue with a European client (F20C) that was due to excessive cooling mods. The ECT was always below 165F, so the car didn't really target stoich. I suspect that this could prevent readiness too.
Bumping this. Can't get my Evap or cat to complete
Following the instruction in the previous posts but the monitors aren't liking my procedures
Evap set, last monitor is the catalyst monitor
Ended up reverting back to stock Honda ecu map. Catalytic monitor didn't end up setting, got the factory ecu map to get the cat readiness to set in 10 minutes
Looks like either I couldn't do it on my tune, or there is a setting on the flashpro, on firmware 2.3.5, that is preventing the catalytic monitor from setting
