2006+ readiness not setting flashpro
Old Aug 18, 2014 | 05:56 AM
SeanGPW's Avatar
Originally Posted by SlowTeg
Have you guys contacted Hondata? I'd think they'd have a more immediate response. Please let us know what you find.. Maybe just run an older version of Flashpro..?
I plugged up the FlashPro and saw I needed a firmware update and I updated it and ran the datalogging and the check emissions and still not ready... will contact them today
Old Aug 18, 2014 | 08:53 AM
crxdx's Avatar
Originally Posted by jojobrown
Originally Posted by EternalLx' timestamp='1408335810' post='23291026
I am getting the same 3 not setting.. My inspection is pass due!
I just bought the car too, and its not passing inspection but its been passing for the last 3 years so not sure what could be the case right now. Wonder why Hondata hasn't done something to force this to pass smh
Hondata is in denial.
I already have they are well aware of the issue. There is tons of people having this issue, whatever they did with one of the updates within the last year is causing this issue. I got over 900 miles logged now and still not set.
Old Aug 18, 2014 | 09:51 AM
SeanGPW's Avatar
Originally Posted by crxdx
Originally Posted by jojobrown' timestamp='1408366154' post='23291287
[quote name='EternalLx' timestamp='1408335810' post='23291026']
[/quote]
I contacted them they said that they have driven a Honda S2000 and have not had issues, I gave them my setup and that they were going to look into it more and get back to me, but got damn if this shit doesn't fix the problem I can't register the car and be shit out of luck even if I put the stock CAT back on, I doubt this will solve issues hoping that once I get back home I can just pull the battery terminal off the battery and wait a few minute and try the follow the guide to get the car back in Readiness to pass.
Old Aug 18, 2014 | 12:16 PM
crxdx's Avatar
I have a whole thread on hondata forums. They do have a s2000 but haven't completed readiness yet, or at least updated the thread. If they can't set readiness hopefully they admit fault.
Old Aug 18, 2014 | 01:51 PM
SeanGPW's Avatar
Can you send me the link? So i can keep up with that thread? I am also gonna remove battery terminal and try to solve that route and have it relearn the readiness procedure.
Old Aug 18, 2014 | 02:03 PM
crxdx's Avatar
http://www.hondata.co/forum/viewtopi...351896&start=0
Old Aug 18, 2014 | 04:36 PM
SeanGPW's Avatar
Well I reset the battery and drove it around, first check was good 0 problems, then started the car and 4 readiness errors, then started driving around and 2 went away and only two remain.... which were the same ones I was having earlier smh honestly not sure what more to do at this point, I don't want to put the OEM cat back on and then try running this because that is just a pain in the ass doing just to pass emissions when previous owner never had any issues
Old Aug 18, 2014 | 05:57 PM
SlowTeg's Avatar
Did you try flashing your car with a stock rom? I see you have VSA disabled, and your radiator fan kicks on at 190 vs. 199F. I'm not sure what else you have changed or whether not reaching a higher temp is causing a problem..?
Old Aug 18, 2014 | 06:04 PM
SeanGPW's Avatar
I have not flash with a stock rom, I was going to switch the J's test pipe out with the OEM cat and try to see if that helps solve the problem, but the thing is the previous owner did not have any issues not sure why it is all happening now
Old Aug 18, 2014 | 07:45 PM
Bunger78's Avatar
I have been attempting to set those same readiness codes with a stock config, pita to put everything back on. Still not set after doing 4 drive cycles.
