AEM 1052u Ems Fan / AC Fan control settings
I have the ECU setup to put both fans on above 195F.
I was wondering if its possible to have this the fan/fans come on above a certain coolant temp but also be able to turn the fans on with the the AC switch?
I have removed the AC
I will tell you its probably possible. Need a multimeter and some damn good electrical knowledge. Basically id put the ac button on a switch for aem. Seems pointless. Race cars have switches partly because they only run flat out. If your overheating in ANY instance this wont do jack for ya bud.
Banned
When you remove all the a/c stuff you loose the circuit that keeps everything working. You need to look in the aem and see if you can still see the a/c switch come on and off. If you can see the switch come on and off then you should be able to toggle the fans w/the switch
