Aem 1052u problem
Old Oct 22, 2013 | 02:13 AM
kordelinos's Avatar
Default Aem 1052u problem
http://www.youtube.com/watch?v=FzBOiOWw8OU
Hello from Greece!!
I have a 2003 Honda S2000 and i have put on it an AEM ems 1052u before a year!!Sudenly i have some problems with my ect volts,and tps volts!!i rec a video for my laptop to show you the "crazy"readings from my car..!!
I always had crazy readings in my ect but never with my tps..
I double checked my wiring connection in an electician and he said it was all clear..
What i must to do..?my car now isnt able to drive,because when i am driving it in town with a little throtle it bogs and i show AFR 16+....
Can you help me with this?
Thanks, Akis
Old Oct 23, 2013 | 06:02 AM
wadzii's Avatar
Banned
Double check your grounds and all the connectors for corrosion.
With the key on and laptop connected unplug sensors one at a time, if everything goes steady then you have an issue with that sensor.
Old Oct 23, 2013 | 06:07 AM
kordelinos's Avatar
I double checked all the grounds..!!my mechanic done..!!
I unplug only the tps when the car is on,and its the same...i will do the sane with the iat,ect,and map?
Thanks for reply wadzii..!!
Old Oct 23, 2013 | 06:10 AM
wadzii's Avatar
Banned
make sure they looked inside all the connectors for corrosion. I have seen that cause all kinds of funny things.
Old Oct 23, 2013 | 11:34 AM
kordelinos's Avatar
If i try to have new ground wirring from battery to engine,throtle body,gearbox,wiil this help?
Old Oct 23, 2013 | 12:30 PM
wadzii's Avatar
Banned
probably not, but it cant hurt.
Something is funny with the sensor ground circuit, which is separate from the chassis ground on the engine
Old Oct 23, 2013 | 02:38 PM
kordelinos's Avatar
should i check on ect sensor?(ground of this)?
if i replace it?
Old Oct 24, 2013 | 12:57 AM
chris_barry's Avatar
An owner in Australia had this problem. The VCC was not stable and needed the ECU repaired to fix. Something to do with a voltage regulator.
Check your car thoroughly to make sure there isnt a wiring/earth issue. Also measure the 5 and 8 volt sensor supplies when the sensors are connected as you will need some load on the supplies.
Old Oct 24, 2013 | 04:28 AM
kordelinos's Avatar
The problem is that i try another Ems 1052 to my car and the ect volts was the same(crazy)readings...
Old Oct 25, 2013 | 12:40 AM
is the earth on the back of the head bolted on tightly?
