Aem back to stock and wont start
Old Apr 11, 2014 | 04:35 PM
odin360's Avatar
Default Aem back to stock and wont start
Hi everybody,
I just finished to pull out a turbo and NO2 setup as its going back to stock, and the car wont start on Oem computer.
It will start with starting fluid. Checked fuel pressure and i have fuel at the rail. Tried 2 oem computers with matching immobilizers so bad computer its excluded. The car runs on the aem.
I know its something electrical but im running out of ideas.
I assume the oem might use some sensors the aem doesnt. Please chime in
Old Apr 12, 2014 | 11:21 AM
wadzii's Avatar
Banned
do you have access to scan tool.. check for codes.
Old Apr 12, 2014 | 04:42 PM
odin360's Avatar
No codes. Scanned all the computers
Old Apr 14, 2014 | 10:27 AM
odin360's Avatar
Yes. And we dint just take the turbo setup off, we swapped in a stock engine that was running fine off another s2k. Both ap1 one 2002 the other 2003.
Old Apr 17, 2014 | 02:27 AM
odin360's Avatar
Nobody?
Old Apr 17, 2014 | 05:55 AM
SlowTeg's Avatar
Not sure how you expect people to diagnose your problem over the interwebs. It sounds like a lot of things changed.. Does the car have spark/fuel? Did you crank the engine and verify? That's step #1. If you want some more help you probably want to provide people with some more info. Was the harness modified at all, maybe a wire got cut? Could be a million different things..
Old Apr 17, 2014 | 10:56 AM
20civic07's Avatar
do you have the aftermarket injectors still installed?
Old Apr 19, 2014 | 04:00 PM
odin360's Avatar
The car is STOCK at this point guys. No harness modification is needed with the Aem. Plug n play.
It starts on starting fluid, have 2 pulses at injectors when 1st cranking than nothing.
I know its hard to diagnostic but i know its electrical and there cant be too many things cutting the injectors, only need a lead
Old Apr 20, 2014 | 05:06 AM
av8ter's Avatar
Immobilizer? Is it the original ECU that came with the car or the one from the swap car?
Old Apr 24, 2014 | 04:27 AM
odin360's Avatar
Ecu was reprogrammed by dealer to match immobilizer. By the dealer it is not the problem.
I am going to replace the crankshaft sensor see if that might do any change.
Thanks for the input
