AEM config for ITB's
Old Mar 15, 2010 | 10:06 PM
chris_barry's Avatar
Default AEM config for ITB's
I'm hoping someone can advise on how to configure a AEM 1052 for this following setup. ( I know Motec backwards/forwards but cannot find all the settings in the AEMpro software)
Fuel and ignition tables are throttle position vs rpm
MAP sensor is vented to atmosphere to be used for barometric compensation.
ie, MAP fuel compensation table so 0kpa=0%, 100kpa=100%, 200kpa=200%.
I found a tick box for speed density in the MAP sensor calibration(unsure what this changes).
I also found a "TPS used for fuel" in the options which seens to get the fuel vs TPS OK.
I cannot find a "TPS used for ign", though I have found a TPS vs load table, perhaps this allows ignition to have an axis of load, but load is a function of TPS as defined by this table.
Old Mar 17, 2010 | 03:23 PM
Got the answer from a friendly AEM guru .
" Go to setup--> sensors--> map sensor --> options.
Uncheck speed density
load offset= 0
Map filter= 0
load scalar= 1
Now go to configure --> units change load units to Percent."
Follow that and leave TPS base fuel map OFF. It will work based on throttle.
The axis or "breakpoints" as we call it is adjustable by clicking on the break point values in the fuel/igni map table views. Just change the value and hit "enter". You will need to adjust it so that the top row on the table is 100%
Also, for the barometric fuel compensation.
The EMS has an internal baro sensor; setup--> sensors--> baro sensor.
Make sure BAR/INP is checked for the baro to be functional. You will also find the Baro correction table under that menu.
Baro compensation is a subject long argued and talked about. I would say adjust it to your needs. Typically if you go up elevation you would need to decrease fuel. A good starting point is 10% less fuel for every drop in 10kpa. Example 80kpa = -20%fuel 110kpa = +10% fuel.
The "TPS based fuel map" option, is if you want to use MAP for Alpha-N hybrid where fuel is based on TPS with MAP compensation, and ignition is based on MAP as usual.
Old Mar 24, 2010 | 08:48 AM
wadzii's Avatar
Banned
you dont want ONLY tps for load.. it will work but its not the best
for ITB's the absolute best way to do it is a combination of boost comp and tps based fuel map. You still want the ignition map to be based on load.
the ems has a built in barometric pressure sensor, but honestly the amount of correction that you would use there is very small.
Old Mar 25, 2010 | 04:27 PM
amusepanda's Avatar
i have aem ems 1012 on its was along with TWM itbs. after i install both of these. can i drive the car normally to get it tuned. how hard is this whole setup?
does anyone know what injectors fit in 52mm TWM
Old Mar 27, 2010 | 07:47 PM
You will need to get a base map from a car with a similar build in order for it to be driveable. If you cant get one then plan on getting the car flat bedded to your tuner. The fuel maps are significantly different to a car with a single TB and it will be unlikely to run or idle.
Old Mar 27, 2010 | 07:50 PM
Thanks for your advice.
Only reason I wanted barometric compensation is one of our race tracks is at enough of an altitude to require 2-3% trim if there is a low pressure over the area as well.
Understand that the boost comp method will also provide these trims.
Old Mar 29, 2010 | 06:18 PM
amusepanda's Avatar
how would i go about getting a similar base map. could i send the ems somehwere and have it set up then sent back to me? does the car have to be on a dyno to have the ems tuned? sorry these are probally stupid questions but you seem to know what your talking about.
Old Mar 29, 2010 | 09:07 PM
You should open a thread and list your modifications/engine build. If you are lucky someone with a similar build may be able to provide you a startup map.
DiegoB16
Mar 31, 2017 10:29 AM
indi00
Mar 7, 2012 02:16 PM
bobonacus
Mar 5, 2012 07:45 AM
S2BOOSTED
Jan 2, 2011 05:02 PM
vietdragontekx
Dec 7, 2010 12:25 AM
