aem ecus
Old Apr 7, 2014 | 07:43 AM
spectacle's Avatar
Originally Posted by passmans2kny
im on the fence between the series 2 and the infinity, evans hasn't tuned an infinity yet, but said hes willing to, not sure which way to go, sure the infnity has all this power, but will it control my car any better than a series 2, doesn't seem so
It's not really a comparison. If you have the coin, get the Infinity.
Old Apr 7, 2014 | 08:39 AM
yamahaSHO's Avatar
They'll both tune the car just fine. Some of the features of the Infinity might be something you're interested in, however, both are good.
Old Apr 16, 2014 | 06:38 AM
Mr.60trim's Avatar
So the Infinity has dual internal wideband controllers...does this essentially negate the need to have a wideband gauge? Also, I have a 5-foot extension harness that theoretically I believe should work with the Infinity s2000 jumper harness...can anyone confirm?
My harness:
AEM s2000 jumper harness:
Old Apr 16, 2014 | 10:33 AM
wadzii's Avatar
Banned
the extension will work fine with the infinity. With the controllers built in there is no need to buy any other wideband controler/gauge
Old Apr 17, 2014 | 03:19 PM
Mr.60trim's Avatar
Thanks
Old Apr 19, 2014 | 07:50 PM
lude92_si's Avatar
I'm in the same boat, talked to Evans and he said stick with the v2 its proven and works. Says AEM always has issues with there new software. He said if it was a full out race car then the infinity would allow more options. I'm also doing flex e85 shooting for 600whp
Old Apr 20, 2014 | 07:17 PM
Mr.60trim's Avatar
Also keep in mind that development on the v2 has ended, there will be no updates, etc for the v2. They are putting all their efforts into the Infinity.
These two points have me torn. Logically, it makes sense to progress forward with the new tech and fall back on the ongoing provided support should you ever need it. However, the v2 has proven itself to be more than capable...and if it ain't broke don't fix it.
Old May 1, 2014 | 08:06 AM
omgitsoop's Avatar
I'm definitely interested in the infinity, I'm hoping that since it was out for a few other models before it came to us, they worked out the kinks on those guinea pigs the few people that do have it seem to love the extra failsafes, and from what I've seen of it, looks like it starts faster? Some cars I've seen on the v2 the motor has to do a full spin to get a readout from the sensors before it actually starts the motor, the infinity seems to do it much faster, but I could be totally wrong about all of that. I'm having trouble shooting you a pm wadzii, could you message me your package price?
Old May 1, 2014 | 07:34 PM
TheCarGuy2021's Avatar
The Infinity 6/8H only has one built in UEGO controller, the Infinity 8/10 has two.
Correct, you don't need a wideband controller/gauge unless you want it there to view. Properly setup failsafes make this less necessary, you can also calibrate the check engine light to turn on under user configurable conditions (lean, overboost, low oil pressure, etc.).
Alternatively, if you already have a wideband controller/gauge, you can plumb the 0-5V output into the Infinity.
Old May 1, 2014 | 07:43 PM
My harness:
If your extension harness is a 100% pass through (has all required terminals populated and no pin swapping/splicing), yes it will work.
Christakis
Feb 8, 2013 01:18 PM
dan_uk
Jun 1, 2012 07:55 AM
abnormals2k
Nov 20, 2010 08:11 PM
The N/A Way
21
Aug 19, 2010 12:28 AM
Kane_X3
Mar 16, 2006 04:02 PM
