AEM EMS ECU OFFLINE!
Old May 31, 2010 | 08:24 AM
JuicedS2K's Avatar
Default AEM EMS ECU OFFLINE!
I have seen threads on this yes, so let me tell you everything i did so far and if you have more tips just chime in...
EMS 1052U
Serial Cable to laptop (no ubs adapter)
Its is set on com port 1 (which is the only option available to choose from)
Tried 3 different laptops.
Tried turning on ignition first then clicking "connect ecu" and vice versa.
I have a solid ground from battery to chassis.
What now???
Old May 31, 2010 | 12:11 PM
Ian300D's Avatar
I could never get the straight Serial to work. Try the Radioshack USB to Serial adapter and try again. Also if your having additional problems you may have what I had, look at my site and scroll through to see some interesting AEM damage.
Old May 31, 2010 | 12:34 PM
JuicedS2K's Avatar
I dont understand what the yellow wire is?? or why you needed to do that?
Old Jun 1, 2010 | 05:22 AM
JuicedS2K's Avatar
Ok, so for anyone wondering, as soon as i connected the EMS directly to the battery it fired right up, so now i have to just run a different power source to the harness...
Old Jun 8, 2010 | 07:39 AM
maluch's Avatar
did you check all your fuses? also check the g101 ground. it is located behind the head and grounds your engine harness.
if that is not it. then plug in an obd2 scanner into your car and try starting it up. the obd2 circuit when connected to an obd2 scanner will also ground your engine harness. this of course is a temporary and hazardous fix since the obd2 circuit does not have a fuse.
Old Jun 8, 2010 | 10:51 PM
SOHCmyDOHC's Avatar
did you check which com port your serial port actually is? Its not necessarily com port 1.
Old Jun 13, 2010 | 09:17 PM
jb34304's Avatar
How the f do you do that?
YuriArts
Jan 27, 2011 07:04 AM
abnormals2k
Nov 20, 2010 08:11 PM
P-CarDriver
Oct 21, 2009 07:40 PM
Kane_X3
Mar 16, 2006 04:02 PM
AusS2000
Feb 19, 2005 07:48 PM
