AEM EMS Noob Question
Old Aug 16, 2010 | 11:55 PM
TerminatioN's Avatar
Default AEM EMS Noob Question
Ok, so I just installed an AEM EMS 1052U and one of the installation steps says:
"g) Verify the ignition timing: Select the “Configure” drop down menu, then “ECU Setup | Set Ignition”. Use a timing light and compare the physical engine timing to the parameter “Ignition Timing” displayed. Use the “Advance/Retard” buttons to make the timing number match."
The problem here is that I don't have a timing light. I will happily get one tomorrow to do it, but will the car be fine to drive to the store without doing the step? Mind you the store is <5 miles from my house and I would baby it the whole way...
If I can't drive the car it will be pretty difficult to get there as I won't have access to another car until the next day...
Anyways, please advise as if I'll be ok.
The car seems to be running "ok". Definitely not running horrible. Just worried I would mess something up somehow by driving it without doing that step.
Please let me know ASAP.
YES, I HAVE TRIED TO SEARCH ALREADY.
Thanks,
-Will
Old Aug 16, 2010 | 11:58 PM
H22toF20's Avatar
You should be fine. You'll probably be off a couple degree's at most anyways, not really enough to warrant not babying it to the store. I would stay out of WOT for sure though.
Maybe someone who knows the base timing could chime in.
Old Aug 17, 2010 | 06:14 AM
ChefJ's Avatar
Thanks,
-Will
try the FI forum you iwll get alot more info in there. Also search that particular forum there are plenty of posts on this subject.
Old Aug 17, 2010 | 07:17 AM
I'm not FI (yet) this is just running NA on the base tune.
Old Aug 17, 2010 | 07:26 AM
ChefJ's Avatar
https://www.s2ki.com/forums/index.php?showforum=231
Old Aug 17, 2010 | 09:47 AM
Originally Posted by ChefJ,Aug 17 2010, 07:26 AM
Thanks. I posted it there but have yet to get any help. I'm also unable to search that forum for some reason. No matter what I search it finds no results...
Old Aug 17, 2010 | 10:07 AM
ChefJ's Avatar
If I had my laptop here I could tell you what it needs to read. If you still need help by tonight I will get you all of that info.
abnormals2k
Jun 28, 2012 04:39 AM
conboracing
Jul 11, 2011 09:41 PM
TerminatioN
Sep 19, 2010 04:12 PM
dsddcd
Mar 14, 2009 12:29 PM
