AEM EMS Tuning Questions
I have read all 213 pages of the AEM manual as well as all the supplemental parts manuals and have a few questions before Mase comes to town. Unfortunately the AEM forum is a bit slow and hard to get info out of.
I have a new 30-1052-U
1) Has anyone used a timing light to verify the AEM timing?
2) Has anyone had luck using the RTD auto tune, if I use a 0-5V input rather than RTD will this feature still work?
3) I still having a hard time understanding how AEM is using the Breakpoints after reading that section at least a dozen times. Can anyone explain it to me in laymen
Dang u actually read it all?!? To answer quickly:
1. Yes, its easy to do so if u have a timing light.
2. Waste of time
3. You can setup the break points however u want. I usually do PSI for the units. and full vac to whatever boost the client is running plus a little more. same w/ the rpms
4. I usually set the CEL to light up if the engine over heats.
5 Yes, you can alter fuel/ign w/ the nitrous outputs
6. im sure you could, u can configure LS and HS outputs.
2. Waste of time
Guess I am going to have to buy another timing light. I sold mine years ago with the intent that I would NEVER adjust a distributor again. At the time GM's Opti spark was awesome over the older HEI.
I am still lost on the break points? The units in the tables seem erroneous and the description is horrible.
Hopefully I will have my stuff together well enough to get the car to you next month.
